Hello
I have a question about snap channel management
When i installed my lxd server by snap i used the snap install lxd command, so I am therefore currently in version 4.9.
What I would like now is to turn off new automatic updates.
I think I understood that I just need to refresh the current channel
snap switch lxd --channel=4.9/stable and thus the tracking will go from latest/stable to 4.9/stable and the automatic refresh of the snap will no longer change the lxd version
Did I understand the operation correctly?
to sum up:
1: lxd installation.
sudo snap install lxd
snap info lxd
snap-id: J60k4JY0HppjwOjW8dZdYc8obXKxujRu
tracking: latest/stable
refresh-date: today at 13:52 UTC
- switch channel:
snap info lxd
tracking: 4.9/stable
and there lxd will never be updated automatically. If I want to update it manually, I will just have to snap refresh --channel=4.10/stable (4.10 is an example)
is this process correct?
