We’ve been having an issue where snap refresh manages to disable lxd for a prolonged period of time.
Containers keep running as normal, but commands remain unavailable for a while (anywhere between a few minutes to a few hours) until the problem fixes itself.
What is the correct way to recover from this manually (snap enable lxd ?) and are there any other logs I can provide to track down the issue?
OS: Ubuntu 20.04.2 LTS
Kernel: 5.4.0-66-generic
# lxc list
zsh: command not found: lxc
# snap logs lxd
2021-06-18T06:06:51Z lxd.daemon[1468466]: 2021/06/18 08:06:51 http: TLS handshake error from 10.80.40.1:51074: EOF
2021-06-18T06:06:51Z lxd.daemon[1468466]: 2021/06/18 08:06:51 http: TLS handshake error from 10.80.40.1:51072: EOF
2021-06-18T06:06:51Z lxd.daemon[1468466]: 2021/06/18 08:06:51 http: TLS handshake error from 10.80.40.1:51076: EOF
2021-06-18T06:07:24Z systemd[1]: Stopping Service for snap application lxd.daemon...
2021-06-18T06:07:28Z lxd.daemon[323967]: => Stop reason is: snap refresh
2021-06-18T06:07:28Z lxd.daemon[323967]: => Stopping LXD
2021-06-18T06:07:31Z lxd.daemon[1468154]: => LXD exited cleanly
2021-06-18T06:07:31Z lxd.daemon[323967]: ==> Stopped LXD
2021-06-18T06:07:31Z systemd[1]: snap.lxd.daemon.service: Succeeded.
2021-06-18T06:07:31Z systemd[1]: Stopped Service for snap application lxd.daemon
# snap refresh lxd
error: cannot refresh "lxd": refreshing disabled snap "lxd" not supported
# snap refresh
All snaps up to date.
# snap info lxd
summary: System container and virtual machine manager
publisher: Canonical✓
store-url: https://snapcraft.io/lxd
contact: https://github.com/lxc/lxd/issues
license: unset
description: <description>
commands: <commands>
services:
lxd.activate: oneshot, disabled, inactive
lxd.daemon: simple, disabled, inactive
snap-id: J60k4JY0HppjwOjW8dZdYc8obXKxujRu
tracking: latest/stable
channels:
latest/stable: 4.15 2021-06-18 (20789) 69MB -
latest/candidate: 4.15 2021-06-18 (20789) 69MB -
latest/beta: ↑
latest/edge: git-7d6ebc4 2021-06-18 (20784) 69MB -
4.15/stable: 4.15 2021-06-18 (20789) 69MB -
4.15/candidate: 4.15 2021-06-18 (20789) 69MB -
4.15/beta: ↑
4.15/edge: ↑
4.14/stable: 4.14 2021-05-18 (20450) 73MB -
4.14/candidate: 4.14 2021-05-18 (20450) 73MB -
4.14/beta: ↑
4.14/edge: ↑
4.13/stable: 4.13 2021-05-04 (20309) 72MB -
4.13/candidate: 4.13 2021-05-04 (20309) 72MB -
4.13/beta: ↑
4.13/edge: ↑
4.0/stable: 4.0.6 2021-05-06 (20326) 70MB -
4.0/candidate: 4.0.6 2021-05-05 (20326) 70MB -
4.0/beta: ↑
4.0/edge: git-23fb72b 2021-06-01 (20535) 66MB -
3.0/stable: 3.0.4 2019-10-10 (11348) 55MB -
3.0/candidate: 3.0.4 2019-10-10 (11348) 55MB -
3.0/beta: ↑
3.0/edge: git-81b81b9 2019-10-10 (11362) 55MB -
2.0/stable: 2.0.12 2020-08-18 (16879) 38MB -
2.0/candidate: 2.0.12 2021-03-22 (19859) 39MB -
2.0/beta: ↑
2.0/edge: git-82c7d62 2021-03-22 (19857) 39MB -
installed: 4.15 (20760) 69MB disabled
and snap logs lxd from when the problem fixes itself:
2021-06-18T08:15:56Z systemd[1]: Starting Service for snap application lxd.activate...
2021-06-18T08:15:56Z lxd.activate[411979]: => Starting LXD activation
2021-06-18T08:15:56Z lxd.activate[411979]: ==> Loading snap configuration
2021-06-18T08:15:56Z lxd.activate[411979]: ==> Checking for socket activation support
2021-06-18T08:15:57Z lxd.activate[411979]: ==> Setting LXD socket ownership
2021-06-18T08:15:57Z lxd.activate[411979]: ==> Checking if LXD needs to be activated
2021-06-18T08:16:00Z systemd[1]: Started Service for snap application lxd.daemon.
2021-06-18T08:16:00Z lxd.daemon[412100]: => Preparing the system (20789)
2021-06-18T08:16:02Z lxd.daemon[412100]: ==> Loading snap configuration
2021-06-18T08:16:02Z lxd.daemon[412100]: ==> Setting up mntns symlink (mnt:[4026532922])
2021-06-18T08:16:03Z lxd.daemon[412100]: ==> Setting up kmod wrapper
2021-06-18T08:16:03Z lxd.daemon[412100]: ==> Preparing /boot
2021-06-18T08:16:03Z lxd.daemon[412100]: ==> Preparing a clean copy of /run
2021-06-18T08:16:03Z lxd.daemon[412100]: ==> Preparing /run/bin
2021-06-18T08:16:03Z lxd.daemon[412100]: ==> Preparing a clean copy of /etc
2021-06-18T08:16:06Z lxd.daemon[412100]: ==> Preparing a clean copy of /usr/share/misc
2021-06-18T08:16:06Z lxd.daemon[412100]: ==> Setting up ceph configuration
2021-06-18T08:16:06Z lxd.daemon[412100]: ==> Setting up LVM configuration
2021-06-18T08:16:06Z lxd.daemon[412100]: ==> Rotating logs
2021-06-18T08:16:46Z lxd.daemon[412100]: ==> Setting up ZFS (0.8)
2021-06-18T08:16:46Z lxd.daemon[412100]: ==> Escaping the systemd cgroups
2021-06-18T08:16:46Z lxd.daemon[412100]: ====> Detected cgroup V1
2021-06-18T08:16:46Z lxd.daemon[412100]: ==> Escaping the systemd process resource limits
2021-06-18T08:16:46Z lxd.daemon[412100]: ==> Disabling shiftfs on this kernel (auto)
2021-06-18T08:16:46Z lxd.daemon[1274626]: Closed liblxcfs.so
2021-06-18T08:16:46Z lxd.daemon[1274626]: Running destructor lxcfs_exit
2021-06-18T08:16:46Z lxd.daemon[1274626]: Running constructor lxcfs_init to reload liblxcfs
2021-06-18T08:16:47Z lxd.daemon[1274626]: mount namespace: 5
2021-06-18T08:16:47Z lxd.daemon[1274626]: hierarchies:
2021-06-18T08:16:47Z lxd.daemon[1274626]: 0: fd: 6:
2021-06-18T08:16:47Z lxd.daemon[1274626]: 1: fd: 7: name=systemd
2021-06-18T08:16:47Z lxd.daemon[1274626]: 2: fd: 8: memory
2021-06-18T08:16:47Z lxd.daemon[1274626]: 3: fd: 9: hugetlb
2021-06-18T08:16:47Z lxd.daemon[1274626]: 4: fd: 10: freezer
2021-06-18T08:16:47Z lxd.daemon[1274626]: 5: fd: 11: perf_event
2021-06-18T08:16:47Z lxd.daemon[1274626]: 6: fd: 12: devices
2021-06-18T08:16:47Z lxd.daemon[1274626]: 7: fd: 13: blkio
2021-06-18T08:16:47Z lxd.daemon[1274626]: 8: fd: 14: cpuset
2021-06-18T08:16:47Z lxd.daemon[1274626]: 9: fd: 15: rdma
2021-06-18T08:16:47Z lxd.daemon[1274626]: 10: fd: 16: net_cls,net_prio
2021-06-18T08:16:47Z lxd.daemon[1274626]: 11: fd: 17: cpu,cpuacct
2021-06-18T08:16:47Z lxd.daemon[1274626]: 12: fd: 19: pids
2021-06-18T08:16:47Z lxd.daemon[1274626]: Kernel supports pidfds
2021-06-18T08:16:47Z lxd.daemon[1274626]: Kernel does not support swap accounting
2021-06-18T08:16:47Z lxd.daemon[1274626]: api_extensions:
2021-06-18T08:16:47Z lxd.daemon[1274626]: - cgroups
2021-06-18T08:16:47Z lxd.daemon[1274626]: - sys_cpu_online
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_cpuinfo
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_diskstats
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_loadavg
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_meminfo
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_stat
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_swaps
2021-06-18T08:16:47Z lxd.daemon[1274626]: - proc_uptime
2021-06-18T08:16:47Z lxd.daemon[1274626]: - shared_pidns
2021-06-18T08:16:47Z lxd.daemon[1274626]: - cpuview_daemon
2021-06-18T08:16:47Z lxd.daemon[1274626]: - loadavg_daemon
2021-06-18T08:16:47Z lxd.daemon[1274626]: - pidfds
2021-06-18T08:16:47Z lxd.daemon[1274626]: Reloaded LXCFS
2021-06-18T08:16:47Z lxd.daemon[412100]: => Re-using existing LXCFS
2021-06-18T08:16:47Z lxd.daemon[412100]: => Starting LXD
2021-06-18T08:16:47Z lxd.daemon[413049]: t=2021-06-18T10:16:47+0200 lvl=warn msg=" - Couldn't find the CGroup blkio.weight, disk priority will be ignored"
2021-06-18T08:16:47Z lxd.daemon[413049]: t=2021-06-18T10:16:47+0200 lvl=warn msg=" - Couldn't find the CGroup memory swap accounting, swap limits will be ignored"
2021-06-18T08:17:07Z systemd[1]: snap.lxd.activate.service: Succeeded.
2021-06-18T08:17:07Z systemd[1]: Finished Service for snap application lxd.activate.
2021-06-18T08:17:11Z lxd.daemon[412100]: => LXD is ready
