Looks like a mount ordering issue in snapd/systemd.
root@nextcloud:~# cat /proc/self/mountinfo | grep fuse
285 282 0:6 /fuse /dev/fuse rw,nosuid,relatime master:2 - devtmpfs udev rw,size=8060160k,nr_inodes=2015040,mode=755
289 284 0:45 / /sys/fs/fuse/connections rw,relatime master:30 - fusectl fusectl rw
300 283 0:51 /proc/cpuinfo /proc/cpuinfo rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
301 283 0:51 /proc/diskstats /proc/diskstats rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
302 283 0:51 /proc/meminfo /proc/meminfo rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
303 283 0:51 /proc/stat /proc/stat rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
304 283 0:51 /proc/swaps /proc/swaps rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
305 283 0:51 /proc/uptime /proc/uptime rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
307 280 0:51 / /var/lib/lxcfs rw,nosuid,nodev,relatime master:104 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
246 280 0:82 / /snap/core/2462 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
247 280 0:83 / /snap/nextcloud/2718 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
248 280 0:84 / /snap/nextcloud/2729 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
250 280 0:85 / /snap/nextcloud/2719 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
251 280 0:86 / /snap/nextcloud/2707 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
253 252 0:82 / /snap/core/2462 ro,nodev,relatime shared:96 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
254 252 0:83 / /snap/nextcloud/2718 ro,nodev,relatime shared:97 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
256 252 0:84 / /snap/nextcloud/2729 ro,nodev,relatime shared:114 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
258 252 0:85 / /snap/nextcloud/2719 ro,nodev,relatime shared:117 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
259 252 0:86 / /snap/nextcloud/2707 ro,nodev,relatime shared:136 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
As you can see, all mount entries under /snap show up duplicated with the only difference that the second entry shows as “shared:XYZ”. It looks like this is caused by a bind-mount of /snap over /snap as is proved below:
root@nextcloud:~# umount /snap/nextcloud/2707
umount: /snap/nextcloud/2707: not mounted
root@nextcloud:~# umount -l /snap/
The root of the problem is that the code which was added to snap-confine to remount /snap MS_SHARED is run AFTER systemd has setup all the .mount units, effectively masking the underlying mount and preventing the unmount unless you get rid of the /snap overmount first.
You can see the bad mount ordering here:
root@nextcloud:~# cat /proc/self/mountinfo | grep \/snap
248 294 0:85 / /snap/nextcloud/2719 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
250 294 0:84 / /snap/core/2462 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
261 294 0:91 / /snap/nextcloud/2729 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
262 294 0:93 / /snap/nextcloud/2718 ro,nodev,relatime - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
263 294 0:43 /rootfs/snap /snap rw,relatime shared:117 master:27 - zfs castiana/lxd/containers/nextcloud rw,xattr,posixacl
264 263 0:85 / /snap/nextcloud/2719 ro,nodev,relatime shared:136 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
265 263 0:84 / /snap/core/2462 ro,nodev,relatime shared:153 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
266 263 0:91 / /snap/nextcloud/2729 ro,nodev,relatime shared:154 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
267 263 0:93 / /snap/nextcloud/2718 ro,nodev,relatime shared:164 - fuse.squashfuse squashfuse ro,user_id=0,group_id=0,allow_other
269 214 0:74 /snapd/ns /run/snapd/ns rw,nosuid,nodev - tmpfs tmpfs rw,mode=755,uid=1000000,gid=1000000
419 269 0:3 mnt:[4026532805] /run/snapd/ns/nextcloud.mnt rw - nsfs nsfs rw
Note that this isn’t container-specific. The same will happen on any system where / isn’t MS_SHARED itself and where snap-confine will therefore overmount /snap.
The remount of /snap MUST happen BEFORE any mount is setup under it.
Please file a bug against snap-confine and point here for the explanation.
PS: This only happens after a restart because that’s when the mis-ordering will happen. Anything which is mounted after the /snap overmount will be perfectly unmountable which is why I couldn’t initially reproduce the issue.
