If one wants to put containers directly on the LAN, what is the current way to do so? In particular, with a cluster? I’ve searched around and the information I’ve found for non-cluster setups doesn’t seem to work for some reason.
On the subject of storage, what’s the general recommendation for shared storage? Ceph? Gluster? Something else?
Can you show the config of your container you’re trying to use lxc config show <container> --expanded and explain what issues you are having so we can try and help. Thanks
I can/will as soon as the cluster is working again. I keep having it go down and freak out with “cannot fetch node config from database: driver: bad connection”
I didn’t want the containers picking up an IP from dnsmasq, so I removed the ipv4 and ipv6 entries from the network config. Now, they won’t go on the network at all, even after putting those entries back. They can’t reach any destination, nor pick up a DHCP address. Even if I manually assign an IP/gateway, nothing
Pretty much the same, whatever server the instance is on will handle the task of creating the snapshots on Ceph. Same for backups, when you make a backup or export a container, whatever server hosts the instance will mount ceph, generate the backup tarball and hose it for you.
So, I have ceph working or at least I think I do. However, upon trying to do my first “lxd init” with 4.0.0 I’m running into this: Error: Failed to create storage pool 'remote': Failed to run: ceph --name client.admin --cluster ceph osd pool create lxd 32: unable to parse addrs in '[v2:XXX.XXX.XXX.XXX:3300/0,v1:XXX.XXX.XXX.XXX:6789/0]'
Where “XXX.XXX.XXX.XXX” is the IP of the Ceph monitor. I’m kinda stuck at this point and not sure where to go
Fails with just one as well in the same manner. I updated the issue to reflect this as well, but I’m wondering if Ceph Octopus is just too new for LXD 4.0.0?
