I have problem with cloud-init, can someone clarify the problem as well? I have tested with a simple cloud-init yaml file but no changes on Centos7/8 distribution, same configuration works as expected in Ubuntu18.04. And also I havent seen any cloud-init log files as well on Centos vms.
Regards.
Simple yaml.file
#cloud-config
locale: en_EN.UTF-8
hostname: testcloud
packages:
- htop
- tree
- cowsay
package_update: true
package_upgrade: true
users:
- name: testuser
groups: wheel
shell: /bin/bash
Here are the commands that executed.
lxc init images:centos/8 c1 -p zfs-default
lxc config set c1 user.user-data - < test.yaml
lxc config show c1
image.architecture: amd64
image.description: Centos 8 amd64 (20200824_07:08)
image.os: Centos
image.release: "8"
image.serial: "20200824_07:08"
image.type: squashfs
user.user-data: "#cloud-config\nlocale: en_EN.UTF-8\nhostname: testcloud\npackages: \n - htop\n - tree\n - cowsay\npackage_update: true\npackage_upgrade: true\nusers:\n - name: testuser\n groups: wheel\n shell: /bin/bash\n\n"
volatile.apply_template: create
volatile.base_image: 77273c7cd804e67b3d16c5d26d4019f4fe525c7510b663d7785c3b6fa1194ffa
volatile.eth0.hwaddr: 00:16:3e:9f:72:03
volatile.idmap.base: "0"
devices: {}
- zfs-default
lxc start c1
lxc exec c1 -- rpm -qa | grep -i cowsay -- nothing displayed.
You need to use the
