killua
March 31, 2024, 10:13am
1
Hi all! I had the brilliant idea to move a lxd server before migrating it to incus to a different network / infra (from 192.168.88.102 to 10.65.0.99) while half asleep. I started to play around with a surrogate lxd instance and dabbled around the “lxd sql global” commands to see what happens under the hood. I managed to be careless and do some of that without noticing on the still in production server until it was too late. I’m now half way there with reviewing the sqlite3 dump and the interface having 192.168.88.102/24 manually added.
2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether d4:5d:df:1a:22:1a brd ff:ff:ff:ff:ff:ff
inet 10.65.0.99/24 metric 100 brd 10.65.0.255 scope global dynamic enp0s31f6
valid_lft 319sec preferred_lft 319sec
inet 192.168.88.102/24 scope global enp0s31f6
inet6 fe80::d65d:dfff:fe1a:221a/64 scope link
On restarting lxd like this, i get
Mar 31 09:51:24 kai02 lxd.daemon[710150]: Device "lxdfan0" does not exist.
Mar 31 09:51:24 kai02 resolvectl[710154]: Failed to resolve interface "lxdfan0": No such device
Before doing more damage, I’m stopping by to say hi and ask for help. pointers on how to un**** my deeds and finish the migration to 10.65.0.99 will be greatly appreciated
killua
March 31, 2024, 11:22am
2
ar 31 11:14:52 kai02 systemd[1]: Starting Service for snap application lxd.daemon...
Mar 31 11:15:12 kai02 lxd.daemon[14626]: => Preparing the system (27049)
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Loading snap configuration
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up mntns symlink (mnt:[4026532476])
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up kmod wrapper
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Preparing /boot
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Preparing a clean copy of /run
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Preparing /run/bin
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Preparing a clean copy of /etc
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Preparing a clean copy of /usr/share/misc
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up ceph configuration
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up LVM configuration
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up OVN configuration
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Rotating logs
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Setting up ZFS (2.1)
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Escaping the systemd cgroups
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ====> Detected cgroup V2
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Escaping the systemd process resource limits
Mar 31 11:15:12 kai02 lxd.daemon[14626]: ==> Exposing LXD documentation
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Closed liblxcfs.so
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Running destructor lxcfs_exit
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Running constructor lxcfs_init to reload liblxcfs
Mar 31 11:15:13 kai02 lxd.daemon[8949]: mount namespace: 6
Mar 31 11:15:13 kai02 lxd.daemon[8949]: hierarchies:
Mar 31 11:15:13 kai02 lxd.daemon[8949]: 0: fd: 8: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Kernel supports pidfds
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Kernel does not support swap accounting
Mar 31 11:15:13 kai02 lxd.daemon[8949]: api_extensions:
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - cgroups
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - sys_cpu_online
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_cpuinfo
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_diskstats
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_loadavg
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_meminfo
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_stat
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_swaps
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_uptime
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - proc_slabinfo
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - shared_pidns
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - cpuview_daemon
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - loadavg_daemon
Mar 31 11:15:13 kai02 lxd.daemon[8949]: - pidfds
Mar 31 11:15:13 kai02 lxd.daemon[8949]: Reloaded LXCFS
Mar 31 11:15:13 kai02 lxd.daemon[14626]: => Re-using existing LXCFS
Mar 31 11:15:13 kai02 lxd.daemon[14626]: ==> Reloading LXCFS
Mar 31 11:15:13 kai02 lxd.daemon[14626]: => Starting LXD
Mar 31 11:15:13 kai02 lxd.daemon[14792]: time="2024-03-31T11:15:13Z" level=warning msg=" - Couldn't find the CGroup network priority controller, per-instance network priority will be ignored. Please use p>
Mar 31 11:15:14 kai02 lxd.daemon[14792]: time="2024-03-31T11:15:14Z" level=error msg="Failed to start the daemon" err="Failed to initialize global database: failed to ensure schema: failed to update node >
Mar 31 11:15:14 kai02 lxd.daemon[14792]: time="2024-03-31T11:15:14Z" level=warning msg="Could not handover member's responsibilities" err="Failed to transfer leadership: No online voter found"
Mar 31 11:15:14 kai02 lxd.daemon[14792]: Error: Failed to initialize global database: failed to ensure schema: failed to update node version info: updated 0 rows instead of 1
Mar 31 11:15:15 kai02 lxd.daemon[14626]: Killed
Mar 31 11:15:15 kai02 lxd.daemon[14626]: => LXD failed to start
Mar 31 11:15:15 kai02 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Mar 31 11:15:27 kai02 lxd.daemon[14839]: Device "lxdfan0" does not exist.
Mar 31 11:15:27 kai02 resolvectl[14843]: Failed to resolve interface "lxdfan0": No such device
Mar 31 11:15:27 kai02 resolvectl[14846]: Failed to resolve interface "lxdfan0": No such device
Mar 31 11:15:27 kai02 systemd[1]: snap.lxd.daemon.service: Control process exited, code=exited, status=1/FAILURE
Mar 31 11:15:27 kai02 systemd[1]: snap.lxd.daemon.service: Failed with result 'exit-code'.
Mar 31 11:15:27 kai02 systemd[1]: Failed to start Service for snap application lxd.daemon.
Mar 31 11:15:28 kai02 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 6.
Mar 31 11:15:28 kai02 systemd[1]: Stopped Service for snap application lxd.daemon.
Mar 31 11:15:28 kai02 systemd[1]: Starting Service for snap application lxd.daemon...
Mar 31 11:15:48 kai02 lxd.daemon[15380]: => Preparing the system (27049)
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Loading snap configuration
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up mntns symlink (mnt:[4026532476])
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up kmod wrapper
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Preparing /boot
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Preparing a clean copy of /run
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Preparing /run/bin
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Preparing a clean copy of /etc
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Preparing a clean copy of /usr/share/misc
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up ceph configuration
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up LVM configuration
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up OVN configuration
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Rotating logs
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Setting up ZFS (2.1)
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Escaping the systemd cgroups
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ====> Detected cgroup V2
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Escaping the systemd process resource limits
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Exposing LXD documentation
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Closed liblxcfs.so
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Running destructor lxcfs_exit
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Running constructor lxcfs_init to reload liblxcfs
Mar 31 11:15:48 kai02 lxd.daemon[8949]: mount namespace: 6
Mar 31 11:15:48 kai02 lxd.daemon[8949]: hierarchies:
Mar 31 11:15:48 kai02 lxd.daemon[8949]: 0: fd: 8: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Kernel supports pidfds
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Kernel does not support swap accounting
Mar 31 11:15:48 kai02 lxd.daemon[8949]: api_extensions:
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - cgroups
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - sys_cpu_online
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_cpuinfo
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_diskstats
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_loadavg
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_meminfo
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_stat
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_swaps
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_uptime
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - proc_slabinfo
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - shared_pidns
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - cpuview_daemon
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - loadavg_daemon
Mar 31 11:15:48 kai02 lxd.daemon[8949]: - pidfds
Mar 31 11:15:48 kai02 lxd.daemon[8949]: Reloaded LXCFS
Mar 31 11:15:48 kai02 lxd.daemon[15380]: => Re-using existing LXCFS
Mar 31 11:15:48 kai02 lxd.daemon[15380]: ==> Reloading LXCFS
Mar 31 11:15:48 kai02 lxd.daemon[15380]: => Starting LXD
Mar 31 11:15:48 kai02 lxd.daemon[15543]: time="2024-03-31T11:15:48Z" level=warning msg=" - Couldn't find the CGroup network priority controller, per-instance network priority will be ignored. Please use p>
Mar 31 11:15:49 kai02 lxd.daemon[15543]: time="2024-03-31T11:15:49Z" level=error msg="Failed to start the daemon" err="Failed to initialize global database: failed to ensure schema: failed to update node >
Mar 31 11:15:49 kai02 lxd.daemon[15543]: time="2024-03-31T11:15:49Z" level=warning msg="Could not handover member's responsibilities" err="Failed to transfer leadership: No online voter found"
Mar 31 11:15:49 kai02 lxd.daemon[15543]: Error: Failed to initialize global database: failed to ensure schema: failed to update node version info: updated 0 rows instead of 1
killua
March 31, 2024, 11:46am
3
Couldn’t resist poking around more. There was a typo on the local db too, so i fixed that and now lxd starts, just the fan network fails to pop to existence
# sqlite3 /var/snap/lxd/common/lxd/database/local.db "select * from config"
2|cluster.https_address|10.65.0.99:9443
4|core.https_address|10.65.0.99:8443
# sqlite3 /var/snap/lxd/common/lxd/database/local.db "select * from raft_nodes"
1|10.65.0.99:9443|0|kai02
killua
March 31, 2024, 12:19pm
4
Progressing:
~$ lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| cni-podman1 | bridge | NO | | | | 0 | |
| cni-podman2 | bridge | NO | | | | 0 | |
| enp0s31f6 | physical | NO | | | | 0 | |
| lxdfan0 | bridge | YES | | | | 23 | CREATED |
| wlp1s0 | physical | NO | | | | 0 | |
after lxc network edit lxdfan0
where I set the
bridge.mode: fan
fan.underlay_subnet: 10.65.0.0/24
ipv4.nat: "true"
some caontainers went up.
killua
March 31, 2024, 12:30pm
5
to make the remaining containers go up, i needed to review
$ lxc config show kai02-gitea
image.architecture: amd64
image.description: Ubuntu bionic amd64 (20181101_07:42)
image.os: Ubuntu
image.release: bionic
image.serial: "20181101_07:42"
volatile.base_image: 72f74ccbb968fca13a680b22d00bbc64636bbc65a870dec79d7c711f7f8b9d85
volatile.eth0.hwaddr: 00:16:3e:e3:e8:34
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.uuid: b9eedd83-f8ac-48e2-999f-af0400a2e10a
gitea-ssh:
bind: host
connect: tcp:127.0.0.1:2222
listen: tcp:192.168.88.102:2222
type: proxy
and use lxc config edit kai02-gitea
to change listen: tcp:192.168.88.102:2222
to the new ip, listen: tcp:10.65.0.99:2222
… this seems to conclude the whole problem,
system
(system)
Closed
April 30, 2024, 12:31pm
6
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
