hi fellas
I am trying to isolate gaming from the rest of my Linux Desktop.
So I installed LXD (snap version) on my Manjaro Linux box and granted access to my X (“Xhost +local:”). Inside Container I am running Bionic/18.04 Ubuntu. I have a working config for running nvidia runtime and I am able to fire up (launch) a container with my profile. I can login, and Glxinfo/Glxgears worx fine. Also I can install games and run them smoothly (like 0ad). I have been even able to run (unfortunately without any sound) Steam and CSGO. Pulseaudio is otherwise working inside my container (tried firefox and vlc).
My Issue:
If I restart the container I cant use X Display anymore.
ubuntu@bionic-nvidia3:~$ glxinfo
Error: unable to open display :0
How Do I fix this issue and get NVIDIA Runtime running again without launching a whole new container?
I can reproduce the issue by fireing up a new container. It works at first but after lxc stop/start I am getting said error … I would really appreciate some help… also I would be happy if anybody could give me a hint about the nosound in steam issue… I tried installing all 32bit pulse and alsa related libs in container and hostsystem but couldnt fix it. I am unsure if this could be related to LXD as well…
Thanks and kind regards!
For audio, check that the Pulseaudio’s socket on the host is indeed /run/user/1000/pulse/native.
For X11 you use a LXD disk device. You can use instead a LXD proxy device (for abstract Unix socket). I have not blogged about this yet but mentioned it on several recent X11 discussions here. I would need to install Manjaro to know what’s wrong but the LXD proxy device is more elegant here.
The Socket Path its correct. Also Pulseaudio inside the container works with firefox and vlc.
I thought I am allready using the Proxy method since I have it in my configs device section:
I solved it using abstract unix sockets as adviced and described here in your / simos posts!
I had to change config accordingly and now containers are surviving restarts
