[Solved] Relationship between iptables/netfilter and LXC
How iptables rules are isolated in a container without effect the rules of host?
In a default instalation of LXD, my host system has the following iptables rules:
$ sudo iptables -t filter -nvL
Chain INPUT (policy ACCEPT 64420 packets, 92M bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 ACCEPT     tcp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53 /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     udp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:53 /* generated for LXD network lxdbr0 */
    2   656 ACCEPT     udp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:67 /* generated for LXD network lxdbr0 */
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
    0     0 ACCEPT     all  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     all  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            /* generated for LXD network lxdbr0 */
Chain OUTPUT (policy ACCEPT 41802 packets, 2566K bytes)
    0     0 ACCEPT     tcp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            tcp spt:53 /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     udp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            udp spt:53 /* generated for LXD network lxdbr0 */
    2   678 ACCEPT     udp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            udp spt:67 /* generated for LXD network lxdbr0 */
I’ve one container:
$ lxc list
|     NAME     |  STATE  |         IPV4         | IPV6 |    TYPE    | SNAPSHOTS |
| firewall-lxc | RUNNING | 10.217.60.109 (eth0) |      | PERSISTENT | 0         |
Listing iptables rules inside on container:
$ lxc exec firewall-lxc -- iptables -t filter -nvL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Inserting a iptables rule on container:
$ lxc exec firewall-lxc -- iptables -t filter -A INPUT -p tcp --dport 80 -j REJECT
    0     0 REJECT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:80 reject-with icmp-port-unreachable
But the rule added on container has no conflict with the rules in host:
Chain INPUT (policy ACCEPT 64713 packets, 92M bytes)
Chain OUTPUT (policy ACCEPT 41972 packets, 2586K bytes)
It’s good… but, how its possible?
It’s thanks to linux network namespaces.
