I have a USB webcam (/dev/webcam0) on the host which i would like to share with the container.
I have defined the device as
webcam0:
mode: "0777"
path: /dev/webcam0
type: unix-char
On the host i can query the webcam,
$ v4l2-ctl -l -d /dev/webcam0
brightness (int) : min=30 max=255 step=1 default=133 value=133
contrast (int) : min=0 max=10 step=1 default=5 value=5
saturation (int) : min=0 max=200 step=1 default=83 value=83
white_balance_temperature_auto (bool) : default=1 value=1
power_line_frequency (menu) : min=0 max=2 default=2 value=2
white_balance_temperature (int) : min=2800 max=10000 step=1 default=4500 value=4500 flags=inactive
sharpness (int) : min=0 max=50 step=1 default=25 value=25
backlight_compensation (int) : min=0 max=10 step=1 default=0 value=0
exposure_auto (menu) : min=0 max=3 default=1 value=3
exposure_absolute (int) : min=5 max=20000 step=1 default=156 value=156 flags=inactive
pan_absolute (int) : min=-201600 max=201600 step=3600 default=0 value=0
tilt_absolute (int) : min=-201600 max=201600 step=3600 default=0 value=0
focus_absolute (int) : min=0 max=40 step=1 default=0 value=20 flags=inactive
focus_auto (bool) : default=0 value=1
However the container gives,
# v4l2-ctl -l -d /dev/webcam0
Failed to open /dev/webcam0: Permission denied
The permissions seem to be quite open in the container,
# ls -la /dev/webcam0
crwxrwxrwx 1 root root 81, 0 Apr 1 05:10 /dev/webcam0
On the host the device is like so,
$ ls -la /dev/webcam0
lrwxrwxrwx 1 root root 6 Apr 1 05:10 /dev/webcam0 -> video0
Any idea why the lxd container is giving that error?
