Hey guys! LXD is great! But I kinda prefer the dpkg packages, honestly. Too bad that it won’t be maintained anymore. I say this because it was working a couple of weeks ago and “out of blue” it broke (never saw this with rock solid dpkg packages).
So, after migrating to the snap LXD package, my contained worked! However, today, some are failing, here is the log:
ubuntu@server:~$ lxc info --show-log coscmpt-1
Remote: unix://
Created: 2019/12/24 04:19 UTC
Status: Stopped
Type: container
Profiles: oscmpts
Log:
lxc coscmpt-1 20200219234710.330 WARN cgfsng - cgroups/cgfsng.c:chowmod:1525 - No such file or directory - Failed to chown(/sys/fs/cgroup/unified//lxc.payload/coscmpt-1/memory.oom.group, 1000000000, 0)
lxc coscmpt-1 20200219234710.404 ERROR utils - utils.c:safe_mount:1212 - Invalid argument - Failed to mount "/proc/sys/fs" onto "/var/snap/lxd/common/lxc//proc/sys/fs"
lxc coscmpt-1 20200219234710.404 ERROR conf - conf.c:mount_entry:2019 - Invalid argument - Failed to mount "/proc/sys/fs" on "/var/snap/lxd/common/lxc//proc/sys/fs"
lxc coscmpt-1 20200219234710.404 ERROR conf - conf.c:lxc_setup:3608 - Failed to setup mount entries
lxc coscmpt-1 20200219234710.404 ERROR start - start.c:do_start:1321 - Failed to setup container "coscmpt-1"
lxc coscmpt-1 20200219234710.405 ERROR sync - sync.c:__sync_wait:62 - An error occurred in another process (expected sequence number 5)
lxc coscmpt-1 20200219234710.405 WARN network - network.c:lxc_delete_network_priv:3377 - Failed to rename interface with index 41 from "ens3" to its initial name "veth85b72178"
lxc coscmpt-1 20200219234710.405 ERROR start - start.c:lxc_abort:1122 - Function not implemented - Failed to send SIGKILL to 5831
lxc coscmpt-1 20200219234710.405 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:873 - Received container state "ABORTING" instead of "RUNNING"
lxc coscmpt-1 20200219234710.405 ERROR start - start.c:__lxc_start:2039 - Failed to spawn container "coscmpt-1"
lxc 20200219234710.563 WARN commands - commands.c:lxc_cmd_rsp_recv:135 - Connection reset by peer - Failed to receive response for command "get_state"
Here is its LXD Profille (that was working about a week ago):
ubuntu@server:~$ lxc profile show oscmpts
raw.lxc: lxc.mount.entry=/proc/sys/fs proc/sys/fs proc bind,rw 0 0
description: OpenStack Compute Nodes (QEMU Hypervisors) - Unrestricted
ens3:
nictype: bridged
parent: br-bond0
pool: default
- /1.0/instances/coscmpt-1
- /1.0/instances/coscmpt-2
Any idea about how to fix it?
