Incus VM’s have the spice server built-in and use the command:
incus console C1 --type=vga
to enter the GUI with the virt-viewer using spice.
Is there a way to install a spice server on an incus ubuntu container (not VM)? I have been known to install a GUI on a container and also an RDP server to gain access to the GUI. The question here is can I install spice server support on an incus container and how?
We could in theory relay that --type=vga traffic over to a spice server running inside the container like Xspice but I’ve not had much luck getting Xspice to work and it’s lacking support for listening on a unix socket which would be a hard requirement for us.
Also, it’d certainly be better if we could have something that supports Wayland these days.
I see your efforts are on par with mine. The documentation is sparse and I certainly understand the emphasis on Wayland. It’s hard to even find folks who have implemented running Spice on other than QEMU.
