Spice viewer for macOS
It’s very cool that my M3 laptop (macOS 14.4) can do “brew install incus” and then add Linux backends as remotes.
However, does anyone know of a spice client for macOS that works? Otherwise all I get is:
% incus console nuc1:jool --type vga
The client automatically uses either spicy or remote-viewer when present.
As neither could be found, the raw SPICE socket can be found at:
  spice+unix:///Users/brian/.config/incus/sockets/3153141961.spice
I tried brew install remoteviewer but it fails to connect to that spice+unix:///... URL.
I tried brew install virt-manager, but it’s missing remote-viewer (and still installs over 150 packages as dependencies - thank goodness for brew autoremove). I gather there are various third-party taps of virt-manager (UPC, jeffreywildman) but I’m a bit dubious about those.
EDIT: Checking on Linux, I found that spicy is in the spice-gtk package. So I tried brew install spice-gtk: again hundreds of dependencies. The first run took about a minute (maybe it was doing Rosetta conversion?). I did get a console in the end, but made the mistake of putting it into full-screen mode, which I was unable to undo. Alt-tab to activity manager, even a regular quit wouldn’t kill it; I had to force-quit. So not a great option.
Any other suggestions?
Thanks,
Brian.
Hmm, in the past brew install remote-viewer did the trick, basically installing it and then running the incus console nuc1:jool --type vga command again so it’d get detected.
Does that fail with an error?
% brew install remote-viewer
Warning: No available formula with the name "remote-viewer".
==> Searching for similarly named formulae and casks...
==> Casks
remoteviewer ✔
I installed “remoteviewer” instead (which installs itself under /Applications/RemoteViewer.app/). But it’s not picked up by incus:
  spice+unix:///Users/brian/.config/incus/sockets/2766333711.spice
If I start RemoteViewer by hand, and then paste in that URL while incus console is sitting there waiting, then it fails:
EDIT: it’s not impossible macOS 14.4 broke something.
Okay, that’s pretty odd. From a shell, can you confirm that the path does exist?
And if it does, maybe try connecting to it with nc -U /Users/brian/...
It could be some kind of MacOS security feature preventing the connection or some issue with Incus creating that listener.
% ls -l /Users/brian/.config/incus/sockets/2766333711.spice
srwxr-xr-x  1 brian  staff  0 22 Mar 16:07 /Users/brian/.config/incus/sockets/2766333711.spice
% nc -U /Users/brian/.config/incus/sockets/2766333711.spice
It hangs at this point so I think it’s connected. And if I type some garbage, I get a response and disconnection:
asdfasdfasdfasdf    << I typed this
REDQ�%              << response
Yep, that suggests that the Incus side of this is working properly then, listening on the unix socket and forwarding the traffic to the Incus server.
What happens when you start remote-viewer unix://... from the command line?
Does it give a more useful error than it does in the GUI?
I have a solution for this.
brew tap jeffreywildman/homebrew-virt-manager
brew install virt-viewer
This works on latest macOS on apple silicon.
Thanks. That does work, although it’s still very slow to start, and it has far too many dependencies (gcc?? numpy??)
I don’t disagree with you… but it’s what we have that works at the moment.
Of course, the other option is to use the web UI.
% ls -l /Applications/RemoteViewer.app/Contents/MacOS
total 608
-rwxr-xr-x@ 1 brian  staff    5697 22 Apr  2013 RemoteViewer
-rwxr-xr-x@ 1 brian  staff  301132 12 Aug  2013 RemoteViewer-bin
% /Applications/RemoteViewer.app/Contents/MacOS/RemoteViewer spice+unix:///Users/brian/.config/incus/sockets/172805119.spice
2024-03-23 10:26:07.234 RemoteViewer-bin[80412:4873929] *** WARNING: Method userSpaceScaleFactor in class NSView is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
(RemoteViewer-bin:80412): GSpice-WARNING **: Expected a URI scheme of 'spice://' in URI 'spice+unix:///Users/brian/.config/incus/sockets/172805119.spice'
Oh OK, it doesn’t support spice+unix :frowning:
I also notice that all the files under /Applications/RemoteViewer.app are timestamped 12 Aug 2013. This is what’s linked from Homebrew, and there’s nothing newer in the dmg directory.
If I use unix instead of spice+unix then it’s different. I don’t get the URL error; what I get instead is “unknown graphic type” in the dialog box:
% /Applications/RemoteViewer.app/Contents/MacOS/RemoteViewer unix:///Users/brian/.config/incus/sockets/919734674.spice
2024-03-23 10:44:35.014 RemoteViewer-bin[80487:4881662] *** WARNING: Method userSpaceScaleFactor in class NSView is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
Then when I click OK:
I installed it and then uninstalled it - the dependencies rang too many alarms, I mean really? libscsi??
Smells of a trojan or some other malware. Suggest caution.
I don’t think it’s likely to be malware, and it can be seen on github here:
but I do think that it would be great if someone would package something on homebrew that works with incus and has fewer dependencies.
It looks like the packages are not signed properly. Or, a malicious code has been inserted here.
==> Verifying attestation for spice-protocol
Error: The bottle for spice-protocol has an invalid build provenance attestation.
This may indicate that the bottle was not produced by the expected
tap, or was maliciously inserted into the expected tap's bottle
storage.
Additional context:
no attestation matches subject
What exactly did you type that caused that error to be shown?
Previously I ran
and it worked for me without that error (and I do still occasionally use it). But I installed it last year sometime.
Also, I’m on Apple processor (M3 Pro), Sonoma 14.5
same command.
jeffreywildman/virt-manager/virt-viewer depends on spice-protocol, usbredir and spice-gtk.
And the signature issue occurs with the spice-protocol.
spice-gtk spicy is now available on Homebrew for macOS Homebrew Formulae: spice-gtk, and it behaves better.
Ergh, it would install 86 dependencies - I think I’ll pass.
==> Downloading bottle manifests
✔︎ Bottle Manifest spice-gtk (0.42_3)
==> Would install 1 formula:
spice-gtk
==> Would install 86 dependencies for spice-gtk:
freetype
fontconfig
glib
xorgproto
libxau
libxdmcp
libxcb
libx11
libxext
libxrender
lzo
cairo
gdk-pixbuf
libvmaf
aom
dav1d
faac
faad2
fdk-aac
mpg123
lame
libvpx
opus
sdl3
sdl2-compat
svt-av1
x264
x265
ffmpeg
libogg
flac
graphene
dbus
libxfixes
libxi
libxtst
at-spi2-core
fribidi
gsettings-desktop-schemas
graphite2
icu4c@78
harfbuzz
hicolor-icon-theme
libepoxy
libdatrie
libthai
pango
gtk+3
librsvg
gtk4
imath
json-glib
libunibreak
libass
libnice
libvorbis
speex
theora
libshout
libsndfile
libsodium
glib-networking
libsoup
libusrsctp
opencore-amr
libdeflate
openjph
openexr
openjpeg
orc
pkgconf
gobject-introspection
py3cairo
pygobject3
rtmpdump
srt
srtp
utf8cpp
taglib
libcuefile
libreplaygain
musepack
gstreamer
phodav
spice-protocol
usbredir
==> Would upgrade 8 dependencies for spice-gtk:
pcre2
ca-certificates
openssl@3
p11-kit
libnghttp2
libpsl
little-cms2
python@3.14
==> Do you want to proceed with the installation? [y/n]
jeffreywildman/homebrew-virt-manager also have similar dependencies.
Apart from the fact that spice-gtk is available in Homebrew directly without needing a tap, it renders the window and menus correctly on macOS, unlike virt-viewer.
That’s fair comment:
virt-viewer
==> Would install 98 dependencies for virt-viewer:
<< snip >>
