So RemoteViewer doesn’t seem to support spice+unix, but it does support spice, i.e. on tcp. Incus is only providing spice+unix. We can use socat to forward a local tcp port to the unix socket:
RemoteViewer 0.5.7 binary was released in 2013 and is Intel-only. So it would be good if someone rebuilds it (in which case, adding spice+unix might be an option)
I found in the source there is a feature for configuring a custom spice client and passing the dynamically chosen socket name:
if preferredSpiceCmd != "" {
// preferredSpiceCmd takes a string where the SOCKET keyword is replaced with the path to the SPICE socket.
cmdSlice, err := shellquote.Split(strings.ReplaceAll(preferredSpiceCmd, "SOCKET", socket))
if err != nil {
return err
This includes the spice+unix:// prefix, so you need a wrapper script to strip that off. I wrote this:
#!/bin/bash -eux
socket="$(echo "$1" | sed -e 's#^spice[+]unix://##' -e 's#%20# #g')"
echo "SOCKET: $socket"
socat TCP-LISTEN:20000,fork "UNIX-CLIENT:$socket" </dev/null &
sleep 1
open -a /Applications/RemoteViewer.app --args spice://localhost:20000
echo "Hit ctrl-C when done"
wait %1
and invoke it from ~/Library/Application\ Support/incus/config.yml:
