SR-IOV and Bridge Communication Issue
I’m running into a networking issue where VMs using different NIC types on the same physical interface can’t communicate with each other, even though they can both reach external hosts.
Setup
  • Host: Debian 12, Incus 6.12
  • NIC: Intel X553 10GbE with SR-IOV enabled (eno1)
  • Bridge: VLAN-aware bridge br0 with eno1 as member
  • VM lab2: Uses SR-IOV with nictype: sriov, parent: eno1, vlan: "41"
  • VM lab3: Uses bridge with nictype: bridged, parent: br0, vlan: "41"
Both VMs get IPs on the same subnet (192.168.41.x) and can communicate with external hosts, but not with each other.
What I’ve Found
Looking at bridge fdb list, lab3’s MAC appears correctly in the forwarding database, but lab2’s MAC (the SR-IOV VM) is missing entirely.
I’ve used a similar SR-IOV/bridge mix with libvirt (though not with VLAN-aware bridges) and it works automatically with no special configuration needed. And for Proxmox I’ve found a thread where manual bridge FDB management is used as a workaround.
Has anyone successfully mixed SR-IOV and bridge networking on the same physical interface with Incus? Is there a recommended approach for this scenario?
