Hello, thanks to the whole incus team for their great work !!
I’ve been recently moving some workload from VMWare… it works marvelous !
Tho, i’ve been recycling a few hardware in the process, and ran into a little problem : i can’t get SR-IOV networks to work properly on an old NC552SFP based on Emulex BladeEngine2.
Thus SRIOV is working properly, all VF gets activated when i boot a container connected to the SR-IOV network (named SRIOV1) sadly, container won’t boot with an error :
Error: Failed to start device "eth1": Failed clearing MAC for VF "0": Failed to run: ip link set dev enp5s0f0 vf 0 mac 00:00:00:00:00:00: exit status 2 (RTNETLINK answers: Invalid argument)
Ran incus info --show-log test-ct
Nom : test-ct
État : STOPPED
Type: container
Architecture : x86_64
Créé : 2024/05/30 19:54 UTC
Last Used: 1970/01/01 00:00 UTC
Journal :
Debugged a bit, and found that be2net kernel module doesn’t like “00:00:00:00:00:00” as incus tries to “reset” Mac Address ![]()
# ip link set enp5s0f0 vf 0 mac 00:00:00:00:00:00
but, interestingly,
ip link set enp5s0f0 vf 0 mac 00:00:00:00:00:01
don’t return an error ![]()
I can set mac address in host profile, it’s not a big deal, but i thought i could use “auto-generated” mac address, with which i’m fine, as i can use it as a filter to limit some loud talking hosts…
(have record of HW macs, and can easily guess virtual ones…)
Had not time to check where is this logic implemented in code, i’ll pay a look by tomorrow, but i’d like to know if it’s a normal and wanted behavior, to reset mac to 00:00:00:00:00:00 if none is provided in conf ?
Thanks for any help provided ![]()
