carlotm
(Carlo Ascani)
April 18, 2024, 7:18am
1
Hi all,
I would like to perform these tasks in Github Actions:
Install and start incus Link to step 1
Launch a void linux container Link to step 2
Set up the container so I can ssh as root into it Link to step 3
The 3rd step is failing, the error is visible at:
Ideas how to solve?
Cheers!
candlerb
(Brian Candler)
April 18, 2024, 7:37am
2
I don’t use void linux, but I don’t see anywhere that you install or start an openssh-server package. Are you sure it’s there?
carlotm
(Carlo Ascani)
April 18, 2024, 7:56am
3
openssh is installed by default in the voidlinux container.
I start it with: dotfiles/.github/workflows/workstation.yml at b1efa90bca397ee2f67157307da99766ab40e1b1 · carlotm/dotfiles · GitHub
Yes, linking the service also starts it in runit. To be on the safe side though, I added commands to start the service and see its status, and now I am getting a different error, which seems related to runit:
force sshd start ans status · carlotm/dotfiles@b1efa90 · GitHub
So you could be right that sshd is just not running correctly.
carlotm
(Carlo Ascani)
April 18, 2024, 9:26am
4
I can confirm sshd is running correctly.
I also tested the same commands locally and it works fine.
I suspect it is a networking problem on the github runner, but I have no idea what to do
