blurry
July 12, 2026, 5:28pm
1
Each time incus-compose down and incus-compose up is invoked, a new set of cgroup inodes for each service in the stack is created, with an incremented numeric suffix. The “stale” inodes remain until the host is rebooted or manually deleted. Would the incus daemon or systemd have eventually reaped them otherwise?
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-1
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-10
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-11
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-12
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-13
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-14
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-15
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-16
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-17
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-18
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-19
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-2
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-20
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-21
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-22
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-23
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-24
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-25
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-26
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-27
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-28
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-29
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-3
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-30
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-31
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-32
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-33
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-34
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-4
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-5
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-6
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-7
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-8
drwxr-xr-x 2 root root 0 Jul 12 13:16 /sys/fs/cgroup/lxc.monitor.immich_server-9
jochumdev
(René Jochum)
July 12, 2026, 5:36pm
2
Thanks blurry, you told me before of that maybe this is a incus bug.
Do you want to test that with plain incus and verify that it happens there as well then post it public?
You can post it public without testing plain as well as you wish.
Thank you,
René
EDIT: I’m blind…
jochumdev
(René Jochum)
July 12, 2026, 5:37pm
3
What I can tell is that I have the same behavior with incus-compose here.
stgraber
(Stéphane Graber)
July 12, 2026, 7:18pm
4
That’d likely be something for @amikhalitsyn to look at. That’s likely an LXC bug as those cgroups should correctly clear on instance stop, allowing for them to be created with the same name on the next start.
The -X syntax is there to deal with edge cases where we may have been unable to destroy the cgroup or where you somehow have two liblxc instances with the same name on the system.
blurry
July 12, 2026, 7:55pm
5
This basically what occurs.
test@eq14-3:~/temp$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 26.04 LTS
Release: 26.04
Codename: resolute
test@eq14-3:~/temp$ incus version
Client version: 7.2
Server version: 7.2
test@eq14-3:~/temp$ incus-compose version
incus-compose version 1.0.0
test@eq14-3:~/temp$ cat docker-compose.yml
services:
web:
container_name: web
image: docker.io/nginx:alpine
ports:
- "8080:80"
volumes:
- ./html:/usr/share/nginx/html:ro
test@eq14-3:~/temp$ ls -ld /sys/fs/cgroup/lxc.monitor.temp*
ls: cannot access '/sys/fs/cgroup/lxc.monitor.temp*': No such file or directory
test@eq14-3:~/temp$ incus-compose up
ensure image docker.io/nginx:alpine [done]
ensure network default [done]
ensure instance web [done]
start instance web [done]
drwxr-xr-x 2 root root 0 Jul 12 15:45 /sys/fs/cgroup/lxc.monitor.temp_web
test@eq14-3:~/temp$ incus-compose down
stop instance web [done]
delete instance web [done]
delete network default [done]
drwxr-xr-x 2 root root 0 Jul 12 15:46 /sys/fs/cgroup/lxc.monitor.temp_web-1
drwxr-xr-x 2 root root 0 Jul 12 15:47 /sys/fs/cgroup/lxc.monitor.temp_web-2
jochumdev
(René Jochum)
July 12, 2026, 7:56pm
6
You write the best reports ever! Not the first time I’ve seen such one from you.
jochumdev
(René Jochum)
July 12, 2026, 8:10pm
7
Could reproduce it with incus cli standalone but only with a network attached:
$ lsb_release -a
LSB Version: n/a
Distributor ID: cachyos
Description: CachyOS
Release: rolling
Codename: n/a
$ incus version
Client version: 7.2
Server version: 7.2
# Some custom build pre 7.3 one.
$ incus project create stale-cgroups
Project stale-cgroups created
$ INCUS_PROJECT=stale-cgroups incus profile device add default root disk path=/ pool=default
Device root added to default
$ INCUS_PROJECT=stale-cgroups incus network create sc0
Network sc0 created
$ INCUS_PROJECT=stale-cgroups incus profile device add default eth0 nic network=sc0
Device eth0 added to default
$ ls -ld /sys/fs/cgroup/lxc.monitor.stale-cgroups_web*
$ INCUS_PROJECT=stale-cgroups incus launch docker.io:library/busybox:glibc web
Launching web
drwxr-xr-x - root 12 Jul 22:07 /sys/fs/cgroup/lxc.monitor.stale-cgroups_web
$ INCUS_PROJECT=stale-cgroups incus rm -f web
Launching web
drwxr-xr-x - root 12 Jul 22:07 /sys/fs/cgroup/lxc.monitor.stale-cgroups_web-1
amikhalitsyn
(Aleksandr Mikhalitsyn)
July 14, 2026, 1:32pm
8
Thanks folks. I can confirm this too, I’m looking into this bug right now.
Upd: LXC fails to cleanup a monitor cgroup, because stateful DHCP client sits inside it. We will discuss this with @stgraber and prepare a fix soon.
