Hi, I have two containers, one with postfix and another one with a backend (web app). I would like to send email to the postfix container using starttls but I have issues
warning: TLS library problem: error:0A000412:SSL routines::sslv3 alert bad certificate:…/ssl/record/rec_layer_s3.c:1605:SSL alert number 42
I think the ssl error is quite obvious, that’s why I use the server domain name to contact the mail server, but I have the following error that I don’t fully understand :
from backend => source: “5.5.2 Error: command not recognized”
Postfix log
improper command pipelining after EHLO from postfix.lxd[10.202.193.100]: QUIT\r\n
I’m able to send email to the postfix server from my backend in a local dev environment (not containerized), this issue only occurs while inside the container.
let email = Message::builder()
.from("nobody@domain.tld".parse().unwrap())
.reply_to("yuin@domain.tld".parse().unwrap())
.to("hei@domain.tld".parse().unwrap())
.subject("Hello test")
.header(ContentType::TEXT_HTML)
.body(String::from("Hello world!"))
.unwrap();
let creds = Credentials::new("smtp_username".to_owned(), "smtp_password".to_owned());
let mailer = SmtpTransport::starttls_relay("mailer.domain.tld")
.unwrap()
.credentials(creds)
.build();
// Send the email
match mailer.send(&email) {
Ok(_) => println!("Email sent successfully!"),
Err(e) => panic!("Could not send email: {e:?}"),
the postfix server works with no issues, except with my containerized backend app. I suspect it has to do with the communication between containers, maybe firewall issue… I tried many things with no results.
Ok I tried with a small python script using smtplib and I’m able to connect with starttls to my postfix server using the container ip mailtest.lxd[10.202.193.250], so the issue might be related to the lettre lib.
