This topic started out as a question, then after doing some digging ended up figuring it out. Going to post it anyway in case anybody has any input that would work just as well or better.
I will be launching several containers across multiple environments, would like to assign static IPv4 addresses to many of them, while also allotting a range for DHCP to pick up as needed anywhere that I do not specify addresses.
One of the first steps:
Running lxc network edit lxdbr0
and specifying ipv4.address
and ipv4.dhcp.ranges
Using 10.1.10.1 as an example:
root@lab001:~# lxc network show lxdbr0
ipv4.address: 10.1.10.1/24
ipv4.dhcp.ranges: 10.1.10.200-10.1.10.254
ipv4.nat: "true"
ipv6.address: <ip>
ipv6.nat: "true"
type: bridge
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
Launching a container without specifying IP address results in assigning within the range.
Setting a static address for a container can be done with a new one in init
before starting, or stopping it first, then updating the network on it, then starting it:
lxc init <image> <container_name>
lxc network attach lxdbr0 <container_name> eth0 eth0
lxc config device set <container_name> eth0 ipv4.address 10.1.10.2
lxc start <container_name>
It gets interesting when introducing multiple levels of nested containers, although the intention here is that containers within one level can communicate with each other. I had to be sure to not introduce conflicting addresses at different levels. For example, I chose to change lab001 above to only specify ipv4.address
and to not specify a dhcp range to open up more flexibility of options with the nested containers within it. I ended up setting both address and range in the 1st level nested container, and chose to reserve a different subnet for each level of nested containers beyond that to help establish a separation across nesting levels, while maintaining connections within each one.
The plan is usually to plug these changes into a script or tool that will automatically run them, basically non-interactive configuration, which means that while the above steps that edit the network (lxdbr0) are useful for learning purposes and to run as needed, they probably cannot be readily used like that in automation, so I turned to the lxd docs:
https://linuxcontainers.org/lxd/docs/master/
A non-interactive replacement for lxc network edit
can be:
lxc network set lxdbr0 ipv4.address 10.1.11.1/24
lxc network set lxdbr0 ipv4.dhcp.ranges 10.1.11.200-10.1.11.254
Another is putting it directly in the preseed yaml.
This is probably common knowledge among many here, either way just throwing it in as a bit of information for anybody that may find it useful. It always helps to reference the docs, it often helps to search through past discussions in here, and sometimes helps to google it before asking about it.
The above worked well for me, although input is welcome if there are other ways or any additional useful options when customizing or otherwise altering addresses and networks.
Update:
A reboot will help refresh network configuration updates, although shouldn’t be necessary if taking the network device down, updating configuration, then bringing the network device up:
ip link set eth0 down
Apply network configuration changes.
ip link set eth0 up
…or…
ip link set lxdbr0 down
ip link set lxdbr0 up
May need some confirmation on just one or both of those, I haven’t tested it yet.
