Apologies if that has been answered before but I’ve been digging through documentation and various forums for hours now and I can’t seem to find a definitive solution.
Essentially, I am able to assign static IPs for LXC containers through the container’s confi but I cannot seem to use the same method to assign static IPs on LXD containers.
My LXC host is running Debian and the containers are connected to an OS managed bridge. There is no DHCP on the container network and the bridge is configured as follows:
auto br1
iface br1 inet manual
bridge_ports ens19
bridge_fd 0
bridge_maxwait 0
An example of a container’s config is:
lxc.apparmor.profile = unconfined
lxc.apparmor.allow_nesting = 1
lxc.rootfs.path = dir:/home/dv-smtp-1/rootfs
# Common configuration
lxc.include = /usr/share/lxc/config/debian.common.conf
lxc.start.auto = 1
lxc.tty.max = 4
lxc.uts.name = dv-smtp-1
lxc.arch = amd64
lxc.pty.max = 1024
lxc.net.0.type = veth
lxc.net.0.link = br1
lxc.net.0.flags = up
lxc.net.0.ipv4.address = 10.0.4.211/24
lxc.net.0.ipv4.gateway = 10.0.4.1
Within the container, /etc/network/interfaces is configured like so:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet manual
Using this method, the container’s IP is configured correctly, as we can see below:
root@dv-smtp-1:/# ip a
inet6 ::1/128 scope host
2: eth0@if36: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:68:1e:2a:c7:61 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.4.211/24 brd 10.0.4.255 scope global eth0
inet6 fe80::68:1eff:fe2a:c761/64 scope link
I’m now building a second host and I want to use LXD instead of LXC. This second host is running Alpine but the OS managed bridge is configured in the same way as the Debian host.
No matter what I’ve tried so far, I cannot seem to replicate my working LXC configuration on LXD. I get “Unknown configuration key: raw.lxc.net.0.ipv4.address” when I try to add the IP directly to the container’s config.
I tried assigning an IP in the device properties section within the container but get this message: "Cannot use manually specified ipv4.address when using unmanaged parent bridge"
I’ve tried creating a managed MACVLAN network but this network type doesn’t seem to support assigning the IP address in the container config.
What is the best way to replicate my LXC setup on LXD?
