I am a newbie to lxc and open vswitch. I am have brought up a Ubuntu VM using lxc launch. I have created an ovs bridge on the host and added my ethernet interface to the ovs bridge. I am able to access the host machine via the ovs bridge.
I intend to run apps on the Ubuntu VM. So, I need to have external traffic coming in and going out from the VM via the ovs bridge
I added one of the VM’s network interface to the ovs bridge using the cmd:
lxc config device add ubuntu-vm1 enp5s0 nic nictype=bridged parent=shashi_ovsbr0
In the VM, I do not see a IP address assigned to the enp5s0 nic interface. I am not sure if my steps are correct or complete. Looking for guidance/help
Thanks @catfish , in the command:
The ‘enp5s0’ interface is the pre-existing interface in the VM which I tried to connect to ovs bridge. I hope this is right
the VM was previously connected to lxdbr0, so I removed the connection and deleted the lxdbr0
I have connected my eth0/eno1 host interface to the ovs bridge and ran dhclient shashi_ovsbr0 from console so that the ovs bridge has direct network access
So, should I modify the command to look like:
lxc config device add ubuntu-vm1 enp5s0 nic nictype=bridged parent=shashi_ovsbr0 name=enp5s0
So when you first run lxc config device add ubuntu-vm1 enp5s0 nic nictype=bridged parent=shashi_ovsbr0, you already disconnected VM to lxdbr0, you just didn’t run dhclient, that why your VM didn’t get an ip, right?
If you run lxc config device add ubuntu-vm1 enp5s0 nic nictype=bridged parent=shashi_ovsbr0 name=enp5s0, I guess you will encounter error, try this: lxc config device override ubuntu-vm1 enp5s0 nic nictype=bridged parent=shashi_ovsbr0 name=enp5s0
And the NIC’s name doesn’t have to be enp5s0, it just need to show in ip a and connects to shashi_ovsbr0.
And wait a moment, I just created a VM, it’s default NIC name is enp5s0. Interesting, container’s default NIC name is eth0. And I added my network profile to it, but the profile is this:
nictype: bridged
parent: ovsbr0
Neither device name and device name in vm is enp5s0. So ignore all cmd above, run all this cmd for test and find out which is the right one, I believe you can learn from failure. And don’t worry if you will run some wrong cmd, you can always take snapshots before taking action. I’ve done a lot trial and error to learn incus features.
lxc config device override ubuntu-vm1 enp5s0 nic name=enp5s0 nictype=bridged parent=shashi_ovsbr0
lxc config device override ubuntu-vm1 enp5s0 nic name=eth0 nictype=bridged parent=shashi_ovsbr0
lxc config device add ubuntu-vm1 eth0 nic name=enp5s0 nictype=bridged parent=shashi_ovsbr0
lxc config device override ubuntu-vm1 eth0 nic name=eth0 nictype=bridged parent=shashi_ovsbr0
Thanks @catfish , I was away on another work. the ovs work got de-prioritized. I will try commands suggested by you once I get back on the task.
Appreciate your help!
