andodeki
(Andrew Odeki)
1
Hey Guys
I am trying to add an Stm32f4 device to my Ubuntu 21.10 container with the followimg command
“lxc config dwvice add dev ttyACM0 unix-char source=/dev/ttyACM0 path=/dev/ttyACM0 mode=0666”
the device is added to to container but i cant flash it since i get
“libusb: error [get_usbfs_fd] libusb couldn’t open USB device /dev/bus/usb/003/010, errno=2”
meaning stlink couldn’t find the device which also i getting as a warning from stlink.
what setting can i make or changes needed kindly guys??
tomp
(Thomas Parrott)
2
Have you tried using the usb
device type?
As the unix-char
will not pass through the /dev/bus/usb
entry.
andodeki
(Andrew Odeki)
3
Like That i get error Still;
lxc config device add zigdev-1 ttyACM1 usb mode=0666 gid=20 path=/dev/ttyACM1
Error: Invalid devices: Device validation failed for "ttyACM1": Invalid device option "path"
tomp
(Thomas Parrott)
4
The usb
device doesn’t have a path
property.
