Hi I am trying to reinstall lxd because I messed up somewhere. Actually I tried to increase the zfs pool size, and closed the terminal abruptly. On restarting I created more problems, so I am trying to reinstall lxd.
In uninstalling lxd, I started deleting everything, but I am unable to delete the default storage pool (the one that I was trying to resize).
lxd storage list:
| default | zfs | /var/snap/lxd/common/lxd/disks/default.img | | 0 | UNAVAILABLE |
and for lxd storage delete default:
Error: Failed to remove directory “/var/snap/lxd/common/lxd/storage-pools/default”: remove /var/snap/lxd/common/lxd/storage-pools/default: directory not empty
How to resolve this? I just want to delete the storage pool and install lxd afresh
