Hello, this is more of a workflow question than a technical question.
I have a largish server that is managed centrally by my institution. I want to run lxd on this server and provide an arbitrary (but probably less than 100) number of containers to others in my department. However, I do not have easy control over the firewall for the host. iptables configuration is centrally managed and changes that I do will be wiped. As far as I understand, if I wanted to grant ssh access to someone, I would need to create iptables rules to forward the traffic from the host to the container bridge. But if containers change regularly, I can’t wait for these firewall changes to be applied.
What would be a good way to handle a situation like this? It might be possible to ask the institution to unblock a ‘pool’ of ports and then forward them dynamically when things change, although this feels a bit manual. Is there any higher-level way to manage this?
There are many options, and it helps if you can talk a bit about what you are really trying to achieve.
For example, are these students that need a Unix shell to do and test their homework?
Further to what Simos said, I would recommend separating the management access to the server (“eth0”) from the container network (“eth1”). This way, you can manage access to the containers separate from the server.
Clients have nearly arbitrary requirements but most would fall into some long number crunching jobs and some low traffic web services. Some containers would need to expose non-SSH services (probably only HTTP) from a public IP eventually.
You don’t need to forward them dynamically. Forward each port to a container according to the last digit of its ip address, regardless of whether the container exists.
Here’s what I do with shorewall, assumming that the lxd bridge network address is 10.129.170.0:
In /etc/shorewall/rules (two-interface configuration) I have:
DNAT net loc:10.129.170.20:22 tcp 7020
DNAT net loc:10.129.170.21:22 tcp 7021
DNAT net loc:10.129.170.99:22 tcp 7099
This maps 80 ports to 80 containers.
I also restrict dhcp to this range:
lxc network set lxdbr0 ipv4.dhcp.ranges 10.129.170.20-10.129.170.99
So I can ssh to any existing or future containers. If I end up using more than 80 containers, I might increase the range accordingly.
I’ve also seen an article describing how to do this port mapping using lxc commands (proxy device), instead of using iptables, but I don’t have it handy.
