elcome to Ubuntu 20.04.2 LTS (GNU/Linux 4.15.0-147-generic x86_64)
- Documentation: https://help.ubuntu.com
- Management: https://landscape.canonical.com
- Support: Ubuntu Advantage for Infrastructure | Ubuntu
System information as of Mon Jul 12 08:03:51 CEST 2021
System load: 0.02 Users logged in: 1
Usage of /: 58.7% of 436.09GB IP address for enp5s0: 95.217.117.93
Memory usage: 1% IP address for vmnet1: 172.16.173.1
Swap usage: 0% IP address for vmnet8: 192.168.85.1
Processes: 264
1144 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Last login: Mon Jul 12 07:56:00 2021 from 185.175.239.145
root@Ubuntu-1804-bionic-64-minimal ~ # apt update
Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
Get:4 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Fetched 114 kB in 1s (175 kB/s)
appstreamcli: symbol lookup error: appstreamcli: undefined symbol: AS_APPSTREAM_METADATA_PATHS
Reading package lists… Done
E: Problem executing scripts APT::Update::Post-Invoke-Success ‘if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi’
E: Sub-process returned an error code
root@Ubuntu-1804-bionic-64-minimal ~ # apt upgrade
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
lxd-client : Depends: lxd (>= 1:0.9) but it is not installed
lxd-tools : Depends: lxd (>= 1:0.9) but it is not installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
root@Ubuntu-1804-bionic-64-minimal ~ # apt autoremove
root@Ubuntu-1804-bionic-64-minimal ~ # lxd version
4.0.6
root@Ubuntu-1804-bionic-64-minimal ~ # sudo apt install policycoreutils
lxd-client : Depends: lxd (>= 1:0.9) but it is not going to be installed
lxd-tools : Depends: lxd (>= 1:0.9) but it is not going to be installed
policycoreutils : Depends: selinux-utils but it is not going to be installed
root@Ubuntu-1804-bionic-64-minimal ~ # echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
root@Ubuntu-1804-bionic-64-minimal ~ # which lxd
/snap/bin/lxd
root@Ubuntu-1804-bionic-64-minimal ~ # lxc --version
4.0.6
root@Ubuntu-1804-bionic-64-minimal ~ # sudo apt install linux-image-generic-hwe-20.04 linux-headers-generic-hwe-20.04
linux-headers-generic-hwe-20.04 : Depends: linux-headers-5.8.0-59-generic but it is not going to be installed
linux-image-generic-hwe-20.04 : Depends: linux-image-5.8.0-59-generic but it is not going to be installed
Depends: linux-modules-extra-5.8.0-59-generic but it is not going to be installed
Recommends: thermald but it is not going to be installed
root@Ubuntu-1804-bionic-64-minimal ~ # apt --fix-broken install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
diffstat gettext gir1.2-clutter-gst-3.0 gir1.2-gtkclutter-1.0 gir1.2-mutter-2 gnome-user-guide intltool-debian iputils-arping irqbalance libapt-pkg-perl libarchive-zip-perl
libboost-date-time1.65.1 libboost-filesystem1.65.1 libboost-iostreams1.65.1 libboost-locale1.65.1 libboost-system1.65.1 libboost-thread1.65.1 libcdio17 libcgi-fast-perl libcgi-pm-perl
libclass-accessor-perl libclone-perl libcroco3 libdouble-conversion1 libebook-contacts-1.2-2 libemail-valid-perl libexempi3 libexiv2-14 libexporter-tiny-perl libfcgi-perl libffi6:i386
libfile-copy-recursive-perl libgail-3-0 libgmime-3.0-0 libgphoto2-l10n libgutenprint-common libgutenprint2 libgutenprint9 libhogweed4:i386 libicu60:i386 libindicator3-7 libio-pty-perl
libio-string-perl libipc-run-perl liblist-moreutils-perl libllvm10 libllvm10:i386 liblxc-common liblxc1 libmagickcore-6.q16-6 libmagickwand-6.q16-6 libmozjs-52-0 libmutter-2-0 libnet-dns-perl
libnet-domain-tld-perl libnet-ip-perl libnettle6:i386 libntfs-3g88 libnuma1 liborcus-0.13-0 libparse-debianchangelog-perl libperl5.26 libperlio-gzip-perl libpoppler73 libpython2.7 libqpdf21
libreoffice-avmedia-backend-gstreamer libreoffice-style-galaxy libsasl2-modules:i386 libspeexdsp1:i386 libtext-levenshtein-perl libunity-gtk2-parser0 libunity-gtk3-parser0 libusbmuxd4
libwacom-bin libxapian30 libxml-simple-perl libyaml-libyaml-perl libzeitgeist-2.0-0 lintian lxcfs patchutils popularity-contest printer-driver-gutenprint python-cairo python-dbus python-gi
python-gi-cairo python-psutil python-talloc python3-lxc qpdf t1utils uidmap unity-gtk-module-common unity-gtk2-module unity-gtk3-module xubuntu-icon-theme zeitgeist-core
Use ‘apt autoremove’ to remove them.
The following additional packages will be installed:
lxd
The following NEW packages will be installed:
lxd
0 upgraded, 1 newly installed, 0 to remove and 595 not upgraded.
2 not fully installed or removed.
Need to get 0 B/5,444 B of archives.
After this operation, 79.9 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Preconfiguring packages …
(Reading database … 249230 files and directories currently installed.)
Preparing to unpack …/archives/lxd_1%3a0.9_all.deb …
=> Installing the LXD snap
==> Checking connectivity with the snap store
==> Installing the LXD snap from the 4.0 track for ubuntu-20.04
snap “lxd” is already installed, see ‘snap help refresh’
==> Waiting for LXD to be online (10min timeout)
==> Running migration from Deb to Snap
=> Connecting to source server
error: Unable to connect to the source LXD: Get “http://unix.socket/1.0”: dial unix /var/lib/lxd/unix.socket: connect: connection refused
dpkg: error processing archive /var/cache/apt/archives/lxd_1%3a0.9_all.deb (–unpack):
new lxd package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
