"sudo incus admin shutdown" makes systemd try to restart Incus?
Hey
Im running Incus on a NixOs (25.11) host and one Nixos (25.11) guest. When I issue “sudo incus admin shutdown” on the host it seems systemd tries to restart it and then end up in some dhcp renewal loop. I guess the dhcp renewal part is a secondary problem here and I just want systemd to stop try to restart Incus when I turned it off deliberately.
Logs:
maj 02 03:00:13 nixos systemd-timesyncd[505]: Contacted time server 162.159.200.1:123 (0.nixos.pool.ntp.org).
maj 02 03:04:45 nixos sudo[4112]:    myuser : TTY=pts/0 ; PWD=/etc/nixos ; USER=root ; COMMAND=/run/current-system/sw/bin/incus admin shutdown
maj 02 03:04:45 nixos sudo[4112]: pam_unix(sudo:session): session opened for user root(uid=0) by myuser(uid=1000)
maj 02 03:04:46 nixos kernel: physzaEg2D: renamed from eth0
maj 02 03:04:46 nixos kernel: br0: port 2(veth558cebed) entered disabled state
maj 02 03:04:46 nixos kernel: veth2a02eea2: renamed from physzaEg2D
maj 02 03:04:46 nixos (udev-worker)[4171]: eth0: Process ‘/nix/store/nilkcchyj1l9ix3ww4p1fby7v00dwkpc-bash-interactive-5.3p3/bin/sh -c ‘echo 2 > /proc/sys/net/ipv6/conf/physzaEg2D/use_tempaddr’’ failed with exi>
maj 02 03:04:46 nixos kernel: br0: port 2(veth558cebed) entered blocking state
maj 02 03:04:46 nixos kernel: br0: port 2(veth558cebed) entered forwarding state
maj 02 03:04:46 nixos kernel: veth558cebed: left allmulticast mode
maj 02 03:04:46 nixos kernel: veth558cebed: left promiscuous mode
maj 02 03:04:46 nixos systemd[1]: var-lib-incus-storage\x2dpools-default-containers-appburken.mount: Deactivated successfully.
maj 02 03:04:46 nixos zed[4228]: eid=100 class=pool_export pool=‘default’ pool_state=EXPORTED
maj 02 03:04:46 nixos zed[4230]: eid=101 class=config_sync pool=‘default’ pool_state=UNINITIALIZED
maj 02 03:04:46 nixos systemd[1]: var-lib-incus-guestapi.mount: Deactivated successfully.
maj 02 03:04:46 nixos systemd[1]: var-lib-incus-shmounts.mount: Deactivated successfully.
maj 02 03:04:46 nixos systemd[1]: var-lib-incus-devices.mount: Deactivated successfully.
maj 02 03:04:46 nixos sudo[4112]: pam_unix(sudo:session): session closed for user root
maj 02 03:04:46 nixos systemd[1]: incus.service: Deactivated successfully.
maj 02 03:04:46 nixos systemd[1]: incus.service: Consumed 12.912s CPU time, 946.7M memory peak, 124.1M read from disk, 216M written to disk, 213.1M incoming IP traffic, 1M outgoing IP traffic.
maj 02 03:04:56 nixos systemd[1]: Starting Incus Container and Virtual Machine Management Daemon…
maj 02 03:04:56 nixos incusd[4238]: time=“2026-05-02T03:04:56+02:00” level=warning msg=“AppArmor support has been disabled because of lack of kernel support”
maj 02 03:04:56 nixos incusd[4238]: time=“2026-05-02T03:04:56+02:00” level=warning msg=" - AppArmor support has been disabled, Disabled because of lack of kernel support"
maj 02 03:04:56 nixos zed[4420]: eid=102 class=history_event pool=‘default’
maj 02 03:04:56 nixos zed[4429]: eid=103 class=config_sync pool=‘default’
maj 02 03:04:56 nixos zed[4430]: eid=104 class=pool_import pool=‘default’
maj 02 03:04:56 nixos zed[4431]: eid=105 class=history_event pool=‘default’
maj 02 03:04:56 nixos zed[4437]: eid=106 class=config_sync pool=‘default’
maj 02 03:04:56 nixos zed[4460]: eid=107 class=history_event pool=‘default’
maj 02 03:04:56 nixos zed[4461]: eid=108 class=history_event pool=‘default’
maj 02 03:04:56 nixos kernel: br0: port 2(veth3176b955) entered blocking state
maj 02 03:04:56 nixos kernel: br0: port 2(veth3176b955) entered disabled state
maj 02 03:04:56 nixos kernel: veth3176b955: entered allmulticast mode
maj 02 03:04:56 nixos kernel: veth3176b955: entered promiscuous mode
maj 02 03:04:56 nixos dhcpcd[878]: br0: 22:d4:35:58:ce:41(22:d4:35:58:ce:41) claims 192.168.1.199
maj 02 03:04:56 nixos dhcpcd[878]: br0: 10 second defence failed for 192.168.1.199
maj 02 03:04:56 nixos dhcpcd[878]: br0: deleting route to 192.168.1.0/24
maj 02 03:04:56 nixos kernel: phys0IZp3u: renamed from veth62ee36bd
maj 02 03:04:56 nixos kernel: eth0: renamed from phys0IZp3u
maj 02 03:04:56 nixos kernel: br0: port 2(veth3176b955) entered forwarding state
maj 02 03:04:57 nixos systemd[1]: Started Incus Container and Virtual Machine Management Daemon.
maj 02 03:04:58 nixos dhcpcd[878]: br0: soliciting a DHCP lease
maj 02 03:05:01 nixos dhcpcd[878]: br0: offered 192.168.1.200 from 192.168.1.1
maj 02 03:05:01 nixos dhcpcd[878]: br0: probing address 192.168.1.200/24
maj 02 03:05:06 nixos incusd[4238]: time=“2026-05-02T03:05:06+02:00” level=warning msg=“Failed to update instance types: Get "https://images.linuxcontainers.org/meta/instance-types/.yaml\”: Unable to connect t>
maj 02 03:05:06 nixos incusd[4238]: time=“2026-05-02T03:05:06+02:00” level=error msg=“Failed updating instance types” err=“Get "https://images.linuxcontainers.org/meta/instance-types/.yaml\”: Unable to connect>
maj 02 03:05:06 nixos dhcpcd[878]: br0: leased 192.168.1.200 for 86400 seconds
maj 02 03:05:06 nixos dhcpcd[878]: br0: adding route to 192.168.1.0/24
maj 02 03:05:06 nixos dhcpcd[878]: br0: adding default route via 192.168.1.1
maj 02 03:05:06 nixos dhcpcd[878]: br0: 22:d4:35:58:ce:41(22:d4:35:58:ce:41) claims 192.168.1.200
maj 02 03:05:06 nixos dhcpcd[878]: br0: 10 second defence failed for 192.168.1.200
maj 02 03:05:06 nixos dhcpcd[878]: br0: deleting route to 192.168.1.0/24
maj 02 03:05:06 nixos dhcpcd[878]: br0: deleting default route via 192.168.1.1
maj 02 03:05:07 nixos dhcpcd[878]: br0: soliciting a DHCP lease
maj 02 03:05:10 nixos dhcpcd[878]: br0: offered 192.168.1.201 from 192.168.1.1
maj 02 03:05:10 nixos dhcpcd[878]: br0: probing address 192.168.1.201/24
maj 02 03:05:15 nixos dhcpcd[878]: br0: leased 192.168.1.201 for 86400 seconds
maj 02 03:05:15 nixos dhcpcd[878]: br0: adding route to 192.168.1.0/24
maj 02 03:05:15 nixos dhcpcd[878]: br0: adding default route via 192.168.1.1
maj 02 03:05:15 nixos dhcpcd[878]: br0: 22:d4:35:58:ce:41(22:d4:35:58:ce:41) claims 192.168.1.201
maj 02 03:05:15 nixos dhcpcd[878]: br0: 10 second defence failed for 192.168.1.201
maj 02 03:05:15 nixos dhcpcd[878]: br0: deleting route to 192.168.1.0/24
maj 02 03:05:15 nixos dhcpcd[878]: br0: deleting default route via 192.168.1.1
maj 02 03:05:16 nixos dhcpcd[878]: br0: soliciting a DHCP lease
maj 02 03:05:19 nixos dhcpcd[878]: br0: offered 192.168.1.202 from 192.168.1.1
maj 02 03:05:19 nixos dhcpcd[878]: br0: probing address 192.168.1.202/24
maj 02 03:05:24 nixos dhcpcd[878]: br0: leased 192.168.1.202 for 86400 seconds
maj 02 03:05:24 nixos dhcpcd[878]: br0: adding route to 192.168.1.0/24
maj 02 03:05:24 nixos dhcpcd[878]: br0: adding default route via 192.168.1.1
…and so on…
