As the heading shows
I installed lxd with the help of
sherab@sherab-librem13v4:~$ snap install lxd
Warning: /snap/bin was not found in your $PATH. If you've not restarted your session since you
installed snapd, try doing that. Please see https://forum.snapcraft.io/t/9469 for more
details.
lxd 4.6 from Canonical✓ installed
lxd is installed but somehow not found.
any advice??
If you are on a desktop session, you need to restart it so that the terminal windows can figure out the updated path. That, or refresh the path manually.
guido@nextcl01:/ $ sudo lxd init
sudo: lxd: command not found
guido@nextcl01:/ $ sudo -i lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
In this forum we have switch to supporting Incus, which is a continuation of LXD.
See the migration to Incus documentation. It should save some memory resources when you do not use the snap package.
