This might be an LXCFS bug, but I thought I’d start here to see if anyone has a good explanation as to why this might not be a bug (or at least not an LXCFS one).
On one particular host, when inside of an LXC container (Ubuntu 18.04), I’m seeing swap jump from 4GB free to 0GB free for fractions of a second. Consider these results:
# for ((n=0;n<20;n++)); do cat /proc/meminfo|grep SwapFree; done
SwapFree: 4194300 kB
SwapFree: 0 kB
SwapFree: 4194044 kB
SwapFree: 0 kB
What could cause available swap to occasionally “flap” between “0” and 4GB available so quickly? This happens with any LXC container on this physical host, even if it’s the only container running at the time and is completely idle. I am unable to reproduce this behavior on the physical host or other LXC containers on another physical host that has the same specs and nearly identical containers running on it.
I realize that this is not enough information to go off of… what additional details can I share here that would be helpful in solving this?
Thanks,
Curtis
