seeing high swap usage and it is not clear why this is happening. :- ![]()
Host was 192 GB of RAM.
We run 18 containers now on host.
Almost all containers configuration use limits.memory and limits.memory.swap.
We also run 4 containers without limitation on memory and swap.
On host:
# free -g
total used free shared buff/cache available
Mem: 187 71 45 4 76 116
Swap: 103 57 46
For reference, here is also the same output, after dropping all caches:
# sync; echo 3 > /proc/sys/vm/drop_caches; free -g
Mem: 187 71 114 5 8 116
Swap: 103 57 46
Host is booted with the following related sysctl options:
vm.swappiness=1
vm.vfs_cache_pressure=60
vm.max_map_count=262144
vm.overcommit_memory = 1
vm.dirty_background_ratio = 5
vm.dirty_ratio = 15
Please note that swappiness is set to 1 on purpose, to avoid swapping as much as possible.
Here are ALL effective sysctl params on âvm.*â namespace:
# sysctl -a|grep 'vm.'
vm.admin_reserve_kbytes = 8192
vm.compact_unevictable_allowed = 1
vm.compaction_proactiveness = 20
vm.dirty_background_bytes = 0
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 15
vm.dirty_writeback_centisecs = 500
vm.dirtytime_expire_seconds = 43200
vm.extfrag_threshold = 500
vm.hugetlb_optimize_vmemmap = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256 256 32 0 0
vm.max_map_count = 262144
vm.memfd_noexec = 0
vm.memory_failure_early_kill = 0
vm.memory_failure_recovery = 1
vm.min_free_kbytes = 67584
vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
vm.mmap_min_addr = 65536
vm.mmap_rnd_bits = 28
vm.mmap_rnd_compat_bits = 8
vm.nr_hugepages = 0
vm.nr_hugepages_mempolicy = 0
vm.nr_overcommit_hugepages = 0
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_ratio = 50
vm.page-cluster = 3
vm.page_lock_unfairness = 5
vm.panic_on_oom = 0
vm.percpu_pagelist_high_fraction = 0
vm.stat_interval = 1
vm.swappiness = 1
vm.unprivileged_userfaultfd = 0
vm.user_reserve_kbytes = 131072
vm.vfs_cache_pressure = 60
vm.watermark_boost_factor = 15000
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
And here is free -g output, inside each running container:
# incus list -c ns --format csv | grep RUNNING | cut -d',' -f1| xargs -I {} sh -c "echo -> {}:; incus exec {} -- free -g"
Mem: 187 0 187 0 0 187
Swap: 103 0 103
Mem: 187 8 179 0 0 179
Swap: 103 12 91
Mem: 187 2 185 0 0 185
Swap: 103 1 102
Mem: 187 10 177 0 0 177
Swap: 103 9 94
Mem: 16 5 7 1 2 8
Swap: 16 2 13
Mem: 12 3 8 0 0 8
Swap: 8 1 6
Mem: 32 4 26 0 0 26
Swap: 8 6 1
Mem: 4 0 3 0 0 3
Swap: 4 0 3
Mem: 10 2 5 0 1 6
Swap: 8 2 5
Mem: 16 4 10 0 0 10
Swap: 8 2 5
Mem: 3 0 2 0 0 2
Swap: 2 0 2
Mem: 4 2 1 0 0 1
Swap: 8 2 5
Mem: 8 1 6 0 0 6
Swap: 8 1 6
Mem: 8 0 7 0 0 7
Swap: 4 0 3
Mem: 8 1 4 0 1 5
Swap: 8 0 7
Mem: 16 4 10 0 1 11
Swap: 8 2 5
Mem: 16 0 14 0 0 15
Swap: 8 1 6
Mem: 16 10 4 0 0 5
Swap: 16 6 9
This is incus 6.1 on Fedora 40 (kernel 6.8.9-300.fc40.x86_64)
Any ideas?
Thank you.
