How can I switch an empty LXD installation from ZFS to BTRFS?
And, because the Raspberry hung his self up when I tried to start my first instance for a test I already ditched the dedicated drive and got a new one.
now lxc list now shows this meaningful:
Error: Get "http://unix.socket/1.0": EOF
root@ubuntu:~# lxd init
Error: Failed to connect to local LXD: Get "http://unix.socket/1.0": EOF
Or how can I start over and use lxd init to put BTRFS as my storage driver?
root@ubuntu:~# snap remove lxd
error: cannot perform the following tasks:
- Stop snap "lxd" services ([--root / enable snap.lxd.daemon.unix.socket] failed with exit status 1: Failed to enable unit, unit snap.lxd.daemon.unix.socket does not exist.
- Remove security profile for snap "lxd" (16945) (cannot find installed snap "lxd" at revision 16945: missing file /snap/lxd/16945/meta/snap.yaml)
- Remove data for snap "lxd" (16103) (remove /var/snap/lxd/common/ns/mntns: device or resource busy)
- Disconnect lxd:lxd-support from snapd:lxd-support (snap "lxd" has no "lxd-support" plug)
- Disconnect lxd:system-observe from snapd:system-observe (snap "lxd" has no "system-observe" plug)
- Disconnect lxd:network-bind from snapd:network-bind (snap "lxd" has no "network-bind" plug)
- Disconnect lxd:network from snapd:network (snap "lxd" has no "network" plug)
It complains about mounts logically
but snap install lxd didn’t let me install it again:
snap "lxd" is already installed, see 'snap help refresh'
I stopped snapd and purged it, followed by a new installation, now I can run lxd init again but, how do I have to prepare my partition for lxd init. It is complaining but I already did format it with mkfs.btrfs /dev/sda1 -f:
Error: Failed to create storage pool 'default': Failed to format block device: Failed to run: mkfs.btrfs /dev/sda1 -L default: /dev/sda1 appears to contain an existing filesystem (btrfs).
ERROR: use the -f option to force overwrite of /dev/sda1
With above error, how can I feed this yaml file to lxd init:
root@ubuntu:~# gdisk /dev/sda1
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Command (? for help): p
Disk /dev/sda1: 488395087 sectors, 232.9 GiB
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): 75D4FE2D-CB97-4B7E-B92C-A8E8DA5B1995
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 488395053
Partitions will be aligned on 2048-sector boundaries
Total free space is 488395020 sectors (232.9 GiB)
Number Start (sector) End (sector) Size Code Name
Command (? for help): d
No partitions
Command (? for help): ?
b back up GPT data to a file
c change a partition's name
d delete a partition
i show detailed information on a partition
l list known partition types
n add a new partition
o create a new empty GUID partition table (GPT)
p print the partition table
q quit without saving changes
r recovery and transformation options (experts only)
s sort partitions
t change a partition's type code
v verify disk
w write table to disk and exit
x extra functionality (experts only)
? print this menu
Command (? for help): x
Expert command (? for help): p
Expert command (? for help): ?
a set attributes
c change partition GUID
d display the sector alignment value
e relocate backup data structures to the end of the disk
f randomize disk and partition unique GUIDs
g change disk GUID
h recompute CHS values in protective/hybrid MBR
j move the main partition table
l set the sector alignment value
m return to main menu
n create a new protective MBR
o print protective MBR data
s resize partition table
t transpose two partition table entries
u replicate partition table on new device
v verify disk
z zap (destroy) GPT data structures and exit
? print this menu
Expert command (? for help): z
About to wipe out GPT on /dev/sda1. Proceed? (Y/N): y
Warning: The kernel is still using the old partition table.
The new table will be used at the next reboot or after you
run partprobe(8) or kpartx(8)
GPT data structures destroyed! You may now partition the disk using fdisk or
other utilities.
Blank out MBR? (Y/N): y
root@ubuntu:~# reboot
When launching my first Instance terminal froze, opening another one failed like there where no network. where can I gather useful information when rebooted?
I’d recommend looking at the kernel log to see if there’s anything suspicious in there which would explain the system no longer responding or disconnecting from the network.
