bitmap_kid
(Bitmap Kid)
November 3, 2019, 11:33am
1
I’m trying to switch an unprivileged container working perfectly with X to Wayland. (I am using lxc 3.0.0 and Plasma)
So, I adapted my config as follows:
#lxc.mount.entry = /tmp/.X11-unix mnt/X11-unix tmpfs bind,none,create=dir 0 0
lxc.mount.entry = /run/user/1001/wayland-0 tmp/wayland-0 none bind,ro,create=file
Alas, during the start, I encountered the following error :
lxc-start steam 20191103110640.437 ERROR utils - utils.c:safe_mount:1187 - Permission denied - Failed to mount "/run/user/1001/wayland-0" onto "/usr/local/lib/lxc/rootfs/tmp/wayland-0"
lxc-start steam 20191103110640.437 ERROR conf - conf.c:mount_entry:2044 - Permission denied - Failed to mount "/run/user/1001/wayland-0" on "/usr/local/lib/lxc/rootfs/tmp/wayland-0"
On the host, I have got user id 1001.
[uu@host1 ~] ls -l /run/user/1001/wayland-0
srwxr-xr-x 1 uu uu 0 3 nov. 11:53 /run/user/1001/wayland-0
What’s happened ? Any suggestion is welcome.
bk
bitmap_kid
(Bitmap Kid)
November 14, 2019, 5:58pm
2
A temporary ugly workaround :
[uu@host ~] sudo chmod 757 /run/user/1001
[uu@host ~] sudo chmod 757 /run/user/1001/wayland-0
My user uu is 1001 on host and 1000 on my unprivileged container.
Maybe a better way is using lxc.idmap rule.
simos
(Simos Xenitellis)
November 14, 2019, 6:20pm
3
So sharing just the Wayland socket (no Xwayland required) you can get the container apps to show up on the host.
While Wayland-only distro are you using?
bitmap_kid
(Bitmap Kid)
November 14, 2019, 9:09pm
4
I’m using ArchLinux, both on host and container. For the moment, I can’t do without Xwayland. In any case, I have not tried to do without it.
simos
(Simos Xenitellis)
November 15, 2019, 1:28pm
5
If you are using Xwayland, why would you need to expose the Wayland Unix socket to the container?
Does the same socket speak X11 and Wayland as well? (This is a Wayland question).
bitmap_kid
(Bitmap Kid)
November 15, 2019, 2:13pm
6
I’m not capable answering you. I can just say, under wayland I don’t have any X11 socket (/tmp/.X11-unix/X0) and not mounting the wayland socket, avoid me starting any gui app. Not sure I am answering your question.
I strongly inspired by :
https://gist.github.com/stueja/447bd3bc0d510a0a7e50f9f1ef58ad75
