I symlinked the images directory:
/var/snap/lxd/common/lxd/images
and then copy from remote fails with:
Error: Failed remote image download: stat /var/snap/lxd/common/lxd/images: no such file or directory
Hello
Don’t use symlinks. Use bind mount, or create a new storage pool.
Take a look at the the following articles: advice on symlinking by the maintainer, how to avoid symlinking, use storage pool
