Is the LXC community planning to implement an option similar to
“security.syscalls.intercept.sysinfo” in LXD?
At this point the syscall sysinfo() shows the amount of memory on the host, instead of that allocated/limited to the LXC container.
This causes a problem, for example, with the LiteSpeed server license (the price of license depends on the amount of memory in the server). I use LXCFS and it emulates /proc/meminfo properly but it doesn’t solve the problem (LiteSpeed uses a kernel syscall function called sysinfo()).
Or maybe there is a solution to this situation?
Thanks and best regards!
