I am trying to install LXD on Redhat, however I think the first time it worked, but then I when i tried to install the ZFS support it mucked it up, then I have reinstalled redhat over and over again , tried instructions and can’t get it work. I have installed squashfs-tools, I keep getting the following error:
[jimbo@redhat ~]$ sudo snap install lxd
error: system does not fully support snapd: cannot mount squashfs image using "squashfs": mount:
/tmp/sanity-mountpoint-897093557: unknown filesystem type 'squashfs'.
So if I run modprobe
[jimbo@redhat ~]$ sudo modprobe squashfs
modprobe: FATAL: Module squashfs not found in directory /lib/modules/4.18.0-147.8.1.el8_1.x86_64
Then I have tried
[jimbo@redhat ~]$ sudo dnf install kernel-modules
Updating Subscription Management repositories.
Last metadata expiration check: 0:21:25 ago on Mon 15 Jun 2020 20:59:28 CEST.
Package kernel-modules-4.18.0-193.el8.x86_64 is already installed.
Package kernel-modules-4.18.0-193.6.3.el8_2.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
I think the issue is caused because I am installing zfs support.
Hmm, yeah, your kernel definitely needs to have squashfs support. But that’s a very common function so something must be quite wrong with your kernel modules…
I already started to reinstall redhat again, but it will pop up again. One thing I noticed, is that I am on redhat 8.2, and the ZFS releases only go upto 8.1, is it possible that this is causing the issue?
Sorry for digging up this post again, but I get the same error on Debian bullseye, I set the loop module as lxc config set <container_name> linux.kernel_modules loop and install fuse package in container and everything runs smoothly.
Regards.
