I observe a very weird and fortunately reproducible problem:
host centos.spd.co.il
causes infinite requests loop between systemd-resolved and LXD’s dnsmasq. So far I see this problem with this specific CentOS domain only. The problem happens when I run this command either on the host or in a container.
I have Ubuntu 18.0.4 server with LXD 3.0.1
The systemd-resolved is configured to resolve the ‘lxd’ domain via lxdbr0 interface. For example:
systemd-resolve --interface lxdbr0 --set-dns 10.159.65.1 --set-domain "lxd"
systemd-resolve --status lxdbr0
Link 4 (lxdbr0)
Current Scopes: DNS
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNS Servers: 10.159.65.1
DNS Domain: lxd
The problem doesn’t happen when I disable DNS for lxdbr0 interface or define it as ‘~lxd’.
I ran systemd-resolved service in debug mode and found that
systemd-resolved[12879]: Processing query...
systemd-resolved[12879]: Got DNS stub UDP query packet for id 27109
systemd-resolved[12879]: Looking up RR for 183.128-255.163.199.212.in-addr.arpa IN PTR.
systemd-resolved[12879]: Cache miss for 183.128-255.163.199.212.in-addr.arpa IN PTR
systemd-resolved[12879]: Transaction 43470 for <183.128-255.163.199.212.in-addr.arpa IN PTR> scope dns on lxdbr0/*.
systemd-resolved[12879]: Using feature level UDP+EDNS0 for transaction 43470.
systemd-resolved[12879]: Using DNS server 10.159.65.1 for transaction 43470.
systemd-resolved[12879]: Sending query packet with id 43470.
systemd-resolved[12879]: Positive cache hit for 183.128-255.163.199.212.in-addr.arpa IN PTR
systemd-resolved[12879]: Transaction 54638 for <183.128-255.163.199.212.in-addr.arpa IN PTR> on scope dns on eno1/* now complete with <success> from cache
systemd-resolved[12879]: Freeing transaction 43470.
systemd-resolved[12879]: Freeing transaction 54638.
systemd-resolved[12879]: Sending response packet with id 27109 on interface 1/AF_INET.
systemd-resolved[12879]: Got DNS stub UDP query packet for id 59106
systemd-resolved[12879]: Transaction 54384 for <183.128-255.163.199.212.in-addr.arpa IN PTR> scope dns on lxdbr0/*.
systemd-resolved[12879]: Using feature level UDP+EDNS0 for transaction 54384.
systemd-resolved[12879]: Using DNS server 10.159.65.1 for transaction 54384.
systemd-resolved[12879]: Sending query packet with id 54384.
systemd-resolved[12879]: Transaction 11243 for <183.128-255.163.199.212.in-addr.arpa IN PTR> on scope dns on eno1/* now complete with <success> from cache
systemd-resolved[12879]: Freeing transaction 54384.
systemd-resolved[12879]: Freeing transaction 11243.
systemd-resolved[12879]: Sending response packet with id 59106 on interface 1/AF_INET.
As you can see the loop is related to resolving of PTR records.
Any idea how to solve this problem? I have many CetOS7 containers and when I run ‘yum update’ inside of one of them the problem starts…
Thank you,
Leonid
