I’m having a problem with the setfacl command, which doesn’t seem to set the correct user uid. However, everything else seems OK.
Here are a few commands to show you :
root@jenkins-agent-8:~ # setfacl -m u:999:r-x /var/tmp/toto
root@jenkins-agent-8:~ # getfacl /var/tmp/toto
# file: var/tmp/toto
# owner: root
# group: root
user::rwx
user:1000999:r-x
group::r-x
mask::r-x
other::r-x
root@jenkins-agent-8:~ # setfacl -m u:jenkins:r-x /var/tmp/toto
getfacl: Removing leading '/' from absolute path names
# owner: root
# group: root
user::rwx
user:1000999:r-x
group::r-x
mask::r-x
other::r-x
root@jenkins-agent-8:~ # getent passwd | grep jenkins
jenkins:x:999:994::/srv/data/jenkins:/bin/bash
root@jenkins-agent-8:~ # chown jenkins:jenkins /var/tmp/toto
root@jenkins-agent-8:~ # ll /var/tmp/
drwxr-xr-x+ 2 jenkins jenkins 2 Oct 9 18:06 toto
root@jenkins-agent-8:~ # ll -n /var/tmp/
drwxr-xr-x+ 2 999 994 2 Oct 9 18:06 toto
It seems that it’s only the setfacl that doesn’t set the right value.
Incus version:
root@srv-374:~ # incus --version
6.0.2
root@srv-374:~ # zfs --version
zfs-2.2.6-1~bpo12+2
zfs-kmod-2.2.6-1~bpo12+2
container config:
root@srv-374:~ # incus config show jenkins-agent-8
image.architecture: amd64
image.description: Debian bookworm amd64 (20241009_05:24)
image.os: Debian
image.release: bookworm
image.serial: "20241009_05:24"
image.type: squashfs
image.variant: default
security.nesting: "true"
volatile.base_image: bea0f1696dc17d7a8002d8d0dd408ad51fa89212e24db1593831b0bed583a5a3
volatile.cloud-init.instance-id: 9d303e99-d032-4ed4-9073-a2d7a9100ee2
volatile.eth304.host_name: veth3a0373fc
volatile.eth304.hwaddr: 00:16:3e:b6:e1:34
volatile.idmap.base: "0"
volatile.uuid: af44b374-d0a2-4ceb-aaa6-8cc8fe7a4eaf
volatile.uuid.generation: 598c27ca-f950-4758-98c4-ce9246ebbbb1
pool: default
- net
- cpu-90-cores
- mem-300GiB
