Terraform-provider-incus - constrast between v0.1.4 and v0.2.0 - expecting VM is running
Version v0.2.0 doesn’t seem to consider that my Windows virtual machines are UP and Running.
After 3min, i have this:
│ Error: Failed to wait for instance "windows-ws-11-0" to start
│   with incus_instance.windows-ws-11[0],
│   on main.tf line 28, in resource "incus_instance" "windows-ws-11":
│   28: resource "incus_instance" "windows-ws-11" {
│ timeout while waiting for state to become 'Running' (last state: 'Running (initializing)', timeout: 3m0s)
However:
$ incus info windows-ws-11-0
Status: RUNNING
Type: virtual-machine
PID: 351642
Created: 2024/11/20 11:26 EST
Last Used: 2024/11/20 11:28 EST
Started: 2024/11/20 11:28 EST
I did the same deployment with v0.1.4 and it finished successfully.
my main.tf
  name      = "windows-ws-11-${count.index}"
  count     = 2
  image     = "win11e"
  type      = "virtual-machine"
  ephemeral = false
  project   = "${incus_project.this.name}"
  profiles  = ["${incus_profile.redacted.name}"]
  wait_for_network = false
  # v0.2.0
  #config = {
  #  "limits.cpu" = 4,
  #  "limits.memory" =  "16GiB"
  device {
    type = "disk"
    name = "root"
    properties = {
      pool = "pool"
      path = "/"
      size = "100GiB"
I’m not sure if it’s a bug in the new version or an addition I’m not aware of.
PS, it seems that the timeout block is not supported? Would this be an interesting addition?
Thank you!
bugfix: fix instance is operational condition by breml · Pull Request #165 · lxc/terraform-provider-incus · GitHub I think that should be fixing this issue
