I’m using LXC through TF and LXD, and also with the difference that LXD installed via snap means, and I’m new to all of them, so please be patient with me.
I have a container with 4 volumes:
$ sudo lxc list
| demo3-node1 | RUNNING | 10.254.254.231 (eth0) | | PERSISTENT | 0 | nimbus |
| | | 10.230.230.1 (eth1) | | | | |
| | | 10.0.3.154 (provision) | | | | |
$ sudo lxc storage volume list local
| TYPE | NAME | DESCRIPTION | USED BY | LOCATION |
| container | demo3-node1 | | 1 | nimbus |
| custom | demo3-node1-cloudian001 | | 1 | nimbus |
| custom | demo3-node1-cloudian002 | | 1 | nimbus |
| custom | demo3-node1-cloudian003 | | 1 | nimbus |
| custom | demo3-node1-cloudian004 | | 1 | nimbus |
The container’s config lists the volumes, but it seems they’re not attached?
$ sudo cat /var/snap/lxd/common/lxd/containers/demo3-node1/backup.yaml
container:
boot.autostart: "1"
image.architecture: x86_64
image.description: Centos 7 x86_64 (20190325_07:08)
image.name: centos-7-x86_64-default-20190325_07:08
image.os: centos
image.release: "7"
image.serial: "20190325_07:08"
image.variant: default
limits.cpu: "4"
limits.memory: 8GB
volatile.base_image: 2d8190b364998ba6edfbcd08509ffce3433f8e84c864a394e9f5c305bacf52f8
volatile.idmap.base: "0"
cloudian001:
path: /cloudian001
pool: local
source: demo3-node1-cloudian001
cloudian002:
path: /cloudian002
pool: local
source: demo3-node1-cloudian002
cloudian003:
path: /cloudian003
pool: local
source: demo3-node1-cloudian003
cloudian004:
path: /cloudian004
pool: local
source: demo3-node1-cloudian004
created_at: 2019-12-18T12:28:18-03:00
expanded_config:
boot.autostart: "1"
image.os: centos
image.release: "7"
limits.cpu: "4"
limits.memory: 8GB
expanded_devices:
cloudian001:
path: /cloudian001
pool: local
cloudian002:
path: /cloudian002
pool: local
cloudian003:
path: /cloudian003
pool: local
cloudian004:
path: /cloudian004
pool: local
pool: local
status: Running
status_code: 103
last_used_at: 2019-12-18T12:28:23.241561778-03:00
snapshots: []
pool:
source: /var/snap/lxd/common/lxd/storage-pools/local
driver: dir
used_by: []
status: Created
locations:
- nimbus
volume:
config: {}
type: container
used_by: []
The container’s config file also mentions them:
$ sudo cat /var/snap/lxd/common/lxd/logs/demo3-node1/lxc.conf
lxc.mount.auto = proc:rw sys:rw
lxc.mount.entry = /dev/fuse dev/fuse none bind,create=file,optional 0 0
lxc.mount.entry = /dev/net/tun dev/net/tun none bind,create=file,optional 0 0
lxc.mount.entry = /proc/sys/fs/binfmt_misc proc/sys/fs/binfmt_misc none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/firmware/efi/efivars sys/firmware/efi/efivars none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/fs/fuse/connections sys/fs/fuse/connections none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/fs/pstore sys/fs/pstore none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/kernel/debug sys/kernel/debug none rbind,create=dir,optional 0 0
lxc.mount.entry = /sys/kernel/security sys/kernel/security none rbind,create=dir,optional 0 0
lxc.mount.entry = /dev/mqueue dev/mqueue none rbind,create=dir,optional 0 0
lxc.mount.entry = /var/snap/lxd/common/lxd/devlxd dev/lxd none bind,create=dir 0 0
lxc.rootfs.path = dir:/var/snap/lxd/common/lxd/containers/demo3-node1/rootfs
lxc.mount.entry = /var/snap/lxd/common/lxd/devices/demo3-node1/disk.cloudian001.cloudian001 cloudian001 none bind,create=dir 0 0
lxc.mount.entry = /var/snap/lxd/common/lxd/devices/demo3-node1/disk.cloudian002.cloudian002 cloudian002 none bind,create=dir 0 0
lxc.mount.entry = /var/snap/lxd/common/lxd/devices/demo3-node1/disk.cloudian003.cloudian003 cloudian003 none bind,create=dir 0 0
lxc.mount.entry = /var/snap/lxd/common/lxd/devices/demo3-node1/disk.cloudian004.cloudian004 cloudian004 none bind,create=dir 0 0
lxc.mount.entry = /var/snap/lxd/common/lxd/shmounts/demo3-node1 dev/.lxd-mounts none bind,create=dir 0 0
I found these two directories named after the volume:
/var/snap/lxd/common/lxd/storage-pools/local/custom/demo3-node1-cloudian001
but none is mounted on the host.
In the container I have:
[root@demo3-node1 ~]# cat /etc/fstab
UUID= /cloudian1 ext4 defaults,rw,nosuid,noexec,nodev,noatime,noinit_itable,data=ordered,errors=remount-ro 0 1
UUID= /cloudian2 ext4 defaults,rw,nosuid,noexec,nodev,noatime,noinit_itable,data=ordered,errors=remount-ro 0 1
UUID= /cloudian3 ext4 defaults,rw,nosuid,noexec,nodev,noatime,noinit_itable,data=ordered,errors=remount-ro 0 1
UUID= /cloudian4 ext4 defaults,rw,nosuid,noexec,nodev,noatime,noinit_itable,data=ordered,errors=remount-ro 0 1
and:
[root@demo3-node1 ~]# mount | grep cloudian | wc -l
0
That means none is mounted in the container either.
So I thought “Maybe they’re not attached. That’s easy!”, but:
$ sudo lxc storage volume attach local demo3-node1-cloudian001 demo3-node1 /cloudian001
Error: Invalid devices: More than one disk device uses the same path: /cloudian001
At this point, I don’t know what else to do. I mentioned that I’m using Terraform; it’s with this backend:
I can provide the main.tf, but I’m not really sure it’s relevant.
