Sometimes when launching a graphical application from a container, I get the following error:
Gdk-ERROR **: xx:xx:xx.xxx: The program 'nemo' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadAccess (attempt to access private resource denied)'.
(Details: serial 184 error_code 10 request_code 130 (MIT-SHM) minor_code 1)
This happens irregularly and with more than 1 program.
The error may appear several times if you try to restart the application after this error, or it may not appear at all.
My setup:
- Host: Linux Mint 20
- Container: Linux Mint 20
- LXD version: 4.11
The container uses a profile with the following configuration for GUI apps:
environment.DISPLAY: :0
X0:
bind: container
connect: unix:@/tmp/.X11-unix/X0
listen: unix:@/tmp/.X11-unix/X0
security.gid: "1000"
security.uid: "1000"
type: proxy
mygpu:
type: gpu
