microcoder
(Vovchik)
1
Hello!
When I run a python-code to my local LXD API I getting error with argument Verify=False
instance_name = 'pgsql'
api_addr = '127.0.0.1:8443'
certs = ('/home/dv/.config/lxc/client.crt', '/home/dv/.config/lxc/client.key')
response = requests.post(f'https://{api_addr}/1.0/instances/{instance_name}/exec', json={}, cert=certs, verify=False)
response = response.json()
Error:
403 not authorized
How can I get access?
microcoder
(Vovchik)
2
Also I tried with cURL:
curl -k --cert /home/dv/.config/lxc/client.crt --key /home/dv/.config/lxc/client.key -X GET https://127.0.0.1:8443/1.0/instances
Response:
{"type":"error","status":"","status_code":0,"operation":"","error_code":403,"error":"not authorized","metadata":null}
stgraber
(Stéphane Graber)
3
Are you sure that client.crt
is trusted by LXD?
You may want to do lxc config trust add ~/.config/lxc/client.crt
to make sure.
Really, it was necessary to add the certificate to the trust! Thank you!
