Trouble scripting container launch
Has anyone had luck making a provisioning script that pulls hostname and IP address from a csv file and looping through the file to launch containers?
Here is my rudimentary script trying to do just that, my csv file is “host-list” formatted as such
c1,192.168.0.222
c2,192.168.0.221
c3,192.168.0.220
c4,192.168.0.219
My bash script:
#! /bin/bash -vx
while IFS=',' read -r name_c1 ip_c2
do
  file=v1-$ip_c2.yaml
  # cat $file
   echo "File" $file
incus launch images:debian/12/cloud "$name_c1" -p prod-mgt --config=cloud-init.network-config="$(cat $file)"
done <  host-list
Gives me this error:
Error: yaml: unmarshal errors:
line 1: cannot unmarshal !!str c2,192.... into api.InstancePut
Seems to struggle with the --config=cloud-init.network-config=“$(cat $file)” section, yet it does render and expand $file. Have used shellcheck to check syntax, but it finds no errors.
Thought I would ask, as others may do the same thing for rapid container deployment.
Thank you
incus launch reads from stdin by default so that’s likely the issue here.
Try to do incus launch ... < /dev/null to force stdin to be closed to avoid this issue.
Ah ok. Thanks for that info Stéphane.
This is a little cleaner:
#! /bin/bash
do
    file=v1-$ip_c2.yaml
    cat >> "$file" << EOF
network:
  version: 1
    - type: physical
      subnets:
        - type: static
          address: $ip_c2/24
          gateway: 192.168.0.1
          dns_nameservers:
            - 192.168.50.50
            - 192.168.0.1
          dns_search:
            - example.com
EOF
# provision containers
incus launch images:debian/12/cloud "$name_c1" -p prod-mgt --config=cloud-init.network-config="$(cat $file)" < /dev/null
done <  host-list
rm v1-*
exit
Edited…
I prefer to avoid the temporary files by putting the config inline: example here. Care is needed if you need inner double quotes, or dollar literals.
Another way might be something bash-specific, like:
( incus launch ... -c user.network-config="$(cat <&3)" -c user.user-data="$(cat <&4)" ) 3<<EOS1 4<<EOS2
version: 2
foo...
EOS1
#cloud-config
bar...
EOS2
Thanks Brian! I was thinking I could do something like this to save on disk I/O, just needed some examples. Just what I was looking for.
Here is what is working for me:
incus launch images:$image_c4 "$name_c1" -p $prof_c3 -c cloud-init.network-config="version: 1
  - type: physical
    subnets:
      - type: static
        address: $ip_c2/24
     - type: nameserver
       address:
         - 192.168.0.1
         - 192.168.50.50
       search:
         - example.lan
" < /dev/null
Tested on several distros with no issues.
Thanks again for all the input!
Just to update this: I found there’s a neater way to handle network-config and user-data, by passing the whole incus “config” block on stdin:
incus launch "$IMAGE" "$NAME" "$@" <<EOS
  cloud-init.network-config: |
    version: 2
    ethernets:
        dhcp4: false
        accept-ra: false
        addresses:
          - $ADDRESS4
          - $ADDRESS6
        routes:
          - to: default
            via: $GATEWAY4
          - to: default
            via: $GATEWAY6
        nameservers:
          search: [$DOMAIN]
          addresses: [$NAMESERVERS]
  cloud-init.user-data: |
    #cloud-config
    disable_root: false
    users: []
    ... etc
EOS
And a neat way to wait until it has finished configuring:
incus exec "$NAME" -- cloud-init status --wait
