I followed several threads to finally get a working static IP address on my unmanaged bridge, br0, but it feels like I made it too complex. Can somebody give this a quick scan and tell me what I can do to simplify this?
In a nutshell, I run “incus config device set kubeadm-leader eth0 security.ipv4_filtering=true ipv4.address=10.0.0.100,” but that doesn’t produce an IP address, it’s blank. I still have to go into Netplan and configure it. So, what is the point in running the command to assign the IP if I just set it with Netplan anyway?
Here is the Incus Profile.
config: {}
description: Unmanaged Bridge Incus profile
nictype: bridged
parent: br0
pool: default
I started with these commands.
incus launch images:ubuntu/22.04 kubeadm-leader --profile homelab
incus stop kubeadm-leader
incus network attach br0 kubeadm-leader eth0 eth0
incus start kubeadm-leader
incus list
At this point, the Linux container is running, but it has no IP address assigned. To fix that, I edit /etc/netplan/10-lxc.yaml like this.
network:
version: 2
ethernets:
dhcp4: false
dhcp-identifier: mac
addresses: [10.0.0.100/16]
nameservers:
addresses:
- 10.0.0.8
- 10.0.0.9
- 10.0.0.1
search: [byteworksinc.com]
routes:
- to: default
via: 10.0.0.1
mtu: 1500
That gives me an IP address and makes the Linux container accessible.
# ip a show
inet6 ::1/128 scope host
66: eth0@if67: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:02:41:8f brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.0.100/16 brd 10.0.255.255 scope global eth0
inet6 fe80::216:3eff:fe02:418f/64 scope link
Is there a more straightforward way?
