Trying to use SR-IOV with Mellanox Infiniband: All virtual functions on device "sriov" are already in use
I was trying to use SR-IOV device with infiniband device type. I get the error below and couldn’t get any more info:
 [root@lx16 ~]# lxc start computenode
Error: All virtual functions on device "sriov" are already in use
Try `lxc info --show-log computenode` for more info
 [root@lx16 ~]# lxc info --show-log computenode
Remote: unix://
Created: 2018/07/27 23:40 UTC
Status: Stopped
Type: persistent
Profiles: default, compute, sr-iov
Snapshots:
Log:
 [root@lx16 ~]# lxc profile show sr-iov
config: {}
  sriov:
    nictype: sriov
    parent: ib0
    type: infiniband
- /1.0/containers/computenode
 [root@lx16 ~]# lspci|grep -i mell
b0:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
b0:00.1 Network controller: Mellanox Technologies MT27500/MT27520 Family [ConnectX-3/ConnectX-3 Pro Virtual Function]
b0:00.2 Network controller: Mellanox Technologies MT27500/MT27520 Family [ConnectX-3/ConnectX-3 Pro Virtual Function]
Can you show:
  • ls -lh /sys/class/net/ib0/device/
  • ls -lh /sys/class/net/ib0/device/virtfn*/
  • ls -lh /sys/class/net/ib0/device/virtfn*/net/
LXD will only consider virtual functions that have network devices listed under net/, otherwise it’s assuming that they’re already in another network namespace and so considered to be in use.
Ah and the values for:
  • cat /sys/class/net/ib0/device/sriov_numvfs
  • cat /sys/class/net/ib0/device/sriov_totalvfs
Would be good to check too, in your case I’d expect it to be 2 in both cases, but worth making sure.
It could also be that you have VFs enabled but don’t have them bound to the IB driver, you can find more details on how I got things going here:
https://github.com/lxc/lxd/issues/3983#issuecomment-340558464
Though that was with ConnectX-4 so the module names may differ in your case.
/sys/class/net/ib0/device/:
# ls -lh /sys/class/net/ib0/device/
total 0
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 broken_parity_status
-r--r--r-- 1 root root 4,0K Tem 28 15:52 class
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 config
-r--r--r-- 1 root root 4,0K Tem 28 15:52 consistent_dma_mask_bits
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 d3cold_allowed
-r--r--r-- 1 root root 4,0K Tem 28 15:52 device
-r--r--r-- 1 root root 4,0K Tem 28 15:52 dma_mask_bits
lrwxrwxrwx 1 root root    0 Tem 28 15:52 driver -> ../../../../bus/pci/drivers/mlx4_core
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 driver_override
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 enable
drwxr-xr-x 3 root root    0 Tem 28 15:52 infiniband
drwxr-xr-x 3 root root    0 Tem 28 15:52 infiniband_cm
drwxr-xr-x 4 root root    0 Tem 28 15:52 infiniband_mad
drwxr-xr-x 3 root root    0 Tem 28 15:52 infiniband_verbs
lrwxrwxrwx 1 root root    0 Tem 28 15:52 iommu -> ../../../virtual/iommu/dmar0
lrwxrwxrwx 1 root root    0 Tem 28 15:52 iommu_group -> ../../../../kernel/iommu_groups/30
-r--r--r-- 1 root root 4,0K Tem 28 15:52 irq
-r--r--r-- 1 root root 4,0K Tem 28 15:52 local_cpulist
-r--r--r-- 1 root root 4,0K Tem 28 15:52 local_cpus
-r--r--r-- 1 root root 4,0K Tem 28 15:52 mlx4_port1
-r--r--r-- 1 root root 4,0K Tem 28 15:52 mlx4_port1_mtu
-r--r--r-- 1 root root 4,0K Tem 28 15:52 modalias
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 msi_bus
drwxr-xr-x 2 root root    0 Tem 28 15:52 msi_irqs
drwxr-xr-x 3 root root    0 Tem 28 15:52 net
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 numa_node
-r--r--r-- 1 root root 4,0K Tem 28 15:52 pools
drwxr-xr-x 2 root root    0 Tem 28 15:52 power
--w--w---- 1 root root 4,0K Tem 28 15:52 remove
--w--w---- 1 root root 4,0K Tem 28 15:52 rescan
--w------- 1 root root 4,0K Tem 28 15:52 reset
-r--r--r-- 1 root root 4,0K Tem 28 15:52 resource
-rw------- 1 root root 1,0M Tem 28 15:52 resource0
-rw------- 1 root root 8,0M Tem 28 15:52 resource2
-rw------- 1 root root 8,0M Tem 28 15:52 resource2_wc
-rw-rw-r-- 1 root root 4,0K Tem 28 15:52 sriov_numvfs
-r--r--r-- 1 root root 4,0K Tem 28 15:52 sriov_totalvfs
lrwxrwxrwx 1 root root    0 Tem 28 15:52 subsystem -> ../../../../bus/pci
-r--r--r-- 1 root root 4,0K Tem 28 15:52 subsystem_device
-r--r--r-- 1 root root 4,0K Tem 28 15:52 subsystem_vendor
-rw-r--r-- 1 root root 4,0K Tem 28 15:52 uevent
-r--r--r-- 1 root root 4,0K Tem 28 15:52 vendor
lrwxrwxrwx 1 root root    0 Tem 28 15:52 virtfn0 -> ../0000:b0:00.1
lrwxrwxrwx 1 root root    0 Tem 28 15:52 virtfn1 -> ../0000:b0:00.2
-rw------- 1 root root  32K Tem 28 15:52 vpd
/sys/class/net/ib0/device/virtfn*/:
# ls -lh /sys/class/net/ib0/device/virtfn*/
/sys/class/net/ib0/device/virtfn0/:
total 0
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 broken_parity_status
-r--r--r-- 1 root root 4,0K Tem 28 15:53 class
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 config
-r--r--r-- 1 root root 4,0K Tem 28 15:53 consistent_dma_mask_bits
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 d3cold_allowed
-r--r--r-- 1 root root 4,0K Tem 28 15:53 device
-r--r--r-- 1 root root 4,0K Tem 28 15:53 dma_mask_bits
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 driver_override
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 enable
lrwxrwxrwx 1 root root    0 Tem 28 15:53 iommu -> ../../../virtual/iommu/dmar0
lrwxrwxrwx 1 root root    0 Tem 28 15:53 iommu_group -> ../../../../kernel/iommu_groups/42
-r--r--r-- 1 root root 4,0K Tem 28 15:53 irq
-r--r--r-- 1 root root 4,0K Tem 28 15:53 local_cpulist
-r--r--r-- 1 root root 4,0K Tem 28 15:53 local_cpus
-r--r--r-- 1 root root 4,0K Tem 28 15:53 modalias
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 msi_bus
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 numa_node
lrwxrwxrwx 1 root root    0 Tem 28 15:53 physfn -> ../0000:b0:00.0
drwxr-xr-x 2 root root    0 Tem 28 15:53 power
--w------- 1 root root 4,0K Tem 28 15:53 reset
-r--r--r-- 1 root root 4,0K Tem 28 15:53 resource
-rw------- 1 root root 8,0M Tem 28 15:53 resource2
-rw------- 1 root root 8,0M Tem 28 15:53 resource2_wc
lrwxrwxrwx 1 root root    0 Tem 28 15:53 subsystem -> ../../../../bus/pci
-r--r--r-- 1 root root 4,0K Tem 28 15:53 subsystem_device
-r--r--r-- 1 root root 4,0K Tem 28 15:53 subsystem_vendor
-rw-r--r-- 1 root root 4,0K Tem 28 15:53 uevent
-r--r--r-- 1 root root 4,0K Tem 28 15:53 vendor
/sys/class/net/ib0/device/virtfn1/:
total 0
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 broken_parity_status
-r--r--r-- 1 root root 4,0K Tem 28 15:54 class
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 config
-r--r--r-- 1 root root 4,0K Tem 28 15:54 consistent_dma_mask_bits
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 d3cold_allowed
-r--r--r-- 1 root root 4,0K Tem 28 15:54 device
-r--r--r-- 1 root root 4,0K Tem 28 15:54 dma_mask_bits
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 driver_override
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 enable
lrwxrwxrwx 1 root root    0 Tem 28 15:54 iommu -> ../../../virtual/iommu/dmar0
lrwxrwxrwx 1 root root    0 Tem 28 15:54 iommu_group -> ../../../../kernel/iommu_groups/43
-r--r--r-- 1 root root 4,0K Tem 28 15:54 irq
-r--r--r-- 1 root root 4,0K Tem 28 15:54 local_cpulist
-r--r--r-- 1 root root 4,0K Tem 28 15:54 local_cpus
-r--r--r-- 1 root root 4,0K Tem 28 15:54 modalias
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 msi_bus
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 numa_node
lrwxrwxrwx 1 root root    0 Tem 28 15:54 physfn -> ../0000:b0:00.0
drwxr-xr-x 2 root root    0 Tem 28 15:54 power
--w------- 1 root root 4,0K Tem 28 15:54 reset
-r--r--r-- 1 root root 4,0K Tem 28 15:54 resource
-rw------- 1 root root 8,0M Tem 28 15:54 resource2
-rw------- 1 root root 8,0M Tem 28 15:54 resource2_wc
lrwxrwxrwx 1 root root    0 Tem 28 15:54 subsystem -> ../../../../bus/pci
-r--r--r-- 1 root root 4,0K Tem 28 15:54 subsystem_device
-r--r--r-- 1 root root 4,0K Tem 28 15:54 subsystem_vendor
-rw-r--r-- 1 root root 4,0K Tem 28 15:54 uevent
-r--r--r-- 1 root root 4,0K Tem 28 15:54 vendor
  • ls -lh /sys/class/net/ib0/device/virtfn*/net/:
    # ls -lh /sys/class/net/ib0/device/virtfn*/net/
    ls: cannot access '/sys/class/net/ib0/device/virtfn*/net/': No such file or directory
So it seems that I do not have.
Yes, both of these returns 2.
If they were not bound to the driver, do they show up in lspci output?
Your output above is consistent with you having VFs enabled but not bound to the driver.
PCI devices will show up regardless of whether a driver is using them or not.
In the post I referred to, you can see me load the driver with both probe_vf and num_vfs set to the number of VFs. The probe_vf property is what instructs the driver to bind to the VFs, only setting num_vfs would get you what you showed above.
