Jeffw
(Jeff)
December 18, 2018, 2:50am
1
I have searched high and low, and apparently my Google fu is not very strong, so I have come here to ask.
How do I go by assigning two mountpoints using separate zfs pools to a container profile? I would like the root mount to be on the ssdraid pool, but have a larger and slower mount to /var on our hddraid pool.
Example:
limits.cpu: “2”
nictype: macvlan
parent: bond0.40
pool: ssd-raid
data:
path: /var
pool: hdd-raid
Thanks for your time.
stgraber
(Stéphane Graber)
December 18, 2018, 2:54pm
2
LXD doesn’t have dynamic allocation of storage volumes, so you can do something like:
lxc storage volume create hdd-raid var
lxc profile device add default data disk path=/var source=var pool=hdd-raid
But that will cause all containers to get the same volume for their /var, which seems unlikely to be what you want.
Instead for now, I suspect you’d want to script your container creation to do something like:
lxc init ubuntu:18.04 NAME
lxc storage volume create hdd-raid NAME-var
lxc config device add NAME data disk path=/var source=NAME-var pool=hdd-raid
lxc start NAME
Only keeping the root device in the default profile.
