Udev requires /dev to be a mounted devtmpfs
Hey guys,
I am running container with the following
$ vi /etc/os-release
NAME=“Alpine Linux”
ID=alpine
VERSION_ID=3.16.2
PRETTY_NAME=“Alpine Linux v3.16”
NAME=“Alpine Linux”
i have attached an Stm32 device added it as a usb device and it can be shown via
lsusb | grep ST-LINK
Bus 003 Device 016: ID 0483:374b STMicroelectronics ST-LINK/V2.1
cmd and
$ ls -la /dev/bus/usb/003/016
crw-rw-rw- 1 root root 189, 270 Oct 13 00:36 /dev/bus/usb/003/016
if i remove the usb and plug it back the number ../016 changes too so its is discovered
if i run this commad
$ st-info --probe
Found 0 stlink programmers
$ st-util
2022-10-13T00:51:28 WARN usb.c: Stlink usb device found, but unable to claim (probably already in use?)
after installing stlink tools i should be able to restart udev with below command which gives an error
$ service udev start
* Udev requires /dev to be a mounted devtmpfs.
* Please reconfigure your system.
* ERROR: udev failed to start
and its status is
$ service udev status
* status: stopped
how do i solve this udev issue??
Is this LXC or LXD?
Its LXD
