I’ve installed ufw on a debian 10 host with the following config
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), deny (routed)
New profiles: skip
To Action From
25/tcp ALLOW IN Anywhere
80/tcp ALLOW IN Anywhere
443/tcp ALLOW IN Anywhere
587/tcp ALLOW IN Anywhere
993/tcp ALLOW IN Anywhere
2200/tcp ALLOW IN Anywhere
25/tcp (v6) ALLOW IN Anywhere (v6)
80/tcp (v6) ALLOW IN Anywhere (v6)
443/tcp (v6) ALLOW IN Anywhere (v6)
587/tcp (v6) ALLOW IN Anywhere (v6)
993/tcp (v6) ALLOW IN Anywhere (v6)
If I try and create a new container e.g.
lxc launch images:debian/buster/amd64 c1
An IP4 address isnt assigned… the workaround is to stop ufw, stop the container, restart the container and then restart ufw…
Does anyone know what the problem might be or is there a better solution?
p.s. I’ve also been exploring the solution in this thread, UFW gets inactive on restart of container but sudo apt update fails… the container isn’t given an IP4 address and apt fails as below…
root@ufw:~# sudo apt update
Err:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Temporary failure resolving 'archive.ubuntu.com'
Err:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
Temporary failure resolving 'security.ubuntu.com'
Err:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Err:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-updates/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-backports/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/InRelease Temporary failure resolving 'security.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
