Hey, I’m having some difficulty mounting a file from a custom volume into a Keycloak OCI container. The UID/GID of the file in the container don’t match the container’s user, causing permission issues. I’ve seen a couple of related topics on here and GitHub but haven’t been able to figure out a solution.
For context: I’m on IncusOS, using the default project and local storage pool. The Keycloak container user has UID 1000.
Steps to reproduce:
# Create container (custom entrypoint for debugging)
incus remote add quay https://quay.io --protocol oci --public
incus init quay:keycloak/keycloak kc --config oci.entrypoint=bash
# Create and attach volume
incus storage volume create local kc-config
echo 'kc config' | incus storage volume file push - local kc-config/keycloak.conf
incus storage volume attach local kc-config/keycloak.conf kc /opt/keycloak/conf/keycloak.conf
# Check keycloak.conf in container
incus start kc
incus exec kc -- ls --numeric-uid-gid /opt/keycloak/conf/keycloak.conf
Output:
-rw-rw---- 1 501 20 10 Jan 25 15:10 /opt/keycloak/conf/keycloak.conf
So the file is mounted with UID/GID 501/20 and mode 0660, which seems random to me. How can I get the permissions/mode to something like 1000/1000/0755?
Following other posts, I’ve tried playing with the options security.shifted=true initial.uid=1000 initial.gid=1000 initial.mode=0755 on the volume and did not see any difference.
Volume config (incus storage volume show local kc-config):
volatile.idmap.last: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000000000},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
type: custom
- /1.0/instances/kc
content_type: filesystem
project: default
created_at: 2026-01-25T15:10:17.03105566Z
Instance config (incus config show kc):
environment.HOME: /opt/keycloak
environment.KC_RUN_IN_CONTAINER: "true"
environment.LANG: en_US.UTF-8
environment.PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
environment.TERM: xterm
image.architecture: x86_64
image.description: quay.io/keycloak/keycloak (OCI)
image.id: keycloak/keycloak
image.type: oci
oci.cwd: /
oci.entrypoint: bash
oci.gid: "0"
oci.uid: "1000"
volatile.base_image: 2a18f117c9f2dcac6430451d3a5117dbf4849a05619fa9a505e666519cd3c1d7
volatile.cloud-init.instance-id: e75e5a35-66cb-4e7c-9504-3a7d2a614888
volatile.container.oci: "true"
volatile.eth0.host_name: vetha073ba1f
volatile.eth0.hwaddr: 10:66:6a:58:70:d5
volatile.idmap.base: "0"
volatile.uuid: 0b810538-8260-40fd-990d-e99cf3f65f4b
volatile.uuid.generation: 0b810538-8260-40fd-990d-e99cf3f65f4b
kc-config/keycloak.conf:
path: /opt/keycloak/conf/keycloak.conf
pool: local
source: kc-config/keycloak.conf
Thanks in advance ![]()
