i’m unable to create container showing the below error.
root@cpu-xxxx:/var/lib/lxd/containers# lxc launch images:debian/buster test
Creating test
Error: Failed instance creation: Create instance: Create instance: Invalid devices: Failed detecting root disk device: No root device could be found
I googled and could see that adding profile will fix the issue. But it shows already exists. Any help would be much appreciated.
