Unable to get bond + vlan to work
I am trying to get IncusOS to bring up a working network configuration through the seed files. My server is connected to the network with two links in a 802.3ad bond with a mandatory VLAN on top of it with a static IP address. Please find my network.yaml below (addresses obfuscated).
I am pretty sure my seed configuration is at least somewhat correct. I created a small tool in the IncusOS repo which allows me to get locally the same files for the systemd-networkd config that IncusOS is creating during the installation phase.
Using these exact files in a plain Debian 13 installation on the same server allows me to bring up a network that at least allows me to successfully ping other network addresses (DNS did not work, but I did not try too hard).
After the startup of IncusOS I see that as network “vlan555” is used with the correct ip address. However I get the warnings that DNS check and NTP sync failed and an error about the check for secure boot key updates. Also the server does not respond to my pings.
At the moment I do not know how to debug or proceed further. Any ideas?
version: ""
dns:
  domain: my.domain
  hostname: myhost
  nameservers:
    - 10.0.0.11
time:
  ntp_servers:
    - 10.0.0.11
  timezone: Etc/GMT
bonds:
  - name: "bond0"
    mode: "802.3ad"
    hwaddr: "aa:bb:cc:dd:ee:5b"
    options:
      transmit_hash_policy: "layer2"
      lacp_rate: "slow"
      mii_monitor_interval: 100
    lldp: false
    members:
      - "aa:bb:cc:dd:ee:5b"
      - "aa:bb:cc:dd:ee:5d"
    mtu: 1500
vlans:
  - id: 555
    addresses:
      - 10.25.0.100/21
    parent: bond0
    routes:
      - to: 0.0.0.0/0
        via: 10.25.0.1
    roles:
      - management
      - instances
The config looks correct to me. Can you confirm that the switch sees the LACP session as established?
Would be interesting to have a system also on VLAN 555 and ping 10.25.0.100 to see if basic L2 is working.
What do you see on screen? Do you see your configured IP address show up at the bottom of the screen?
It could also be some kind of MAC filtering on the switch as IncusOS will still use some other MAC addresses for its built-in switch which could trip some checks, so looking at the switch logs would be useful.
Other than that, any more details on the IncusOS version and NIC model would be useful.
