Hello. I am having a networking issue that I cannot seem to solve.
Starting an OpenVPN client inside a container makes the container stop responding to outside pings. Without OpenVPN, I am able to ping the container from another computer on the same LAN, using it’s lxdbr IP. After the vpn connection is made, I can no longer reach the container from another computer, which means I can no longer access services running in that container from the LAN. I can still ping the container from the LXD host, or from other containers on the same host. Of note, I am using the update-systemd-resolved script provided with OpenVPN.
Here is how things are set up:
LXD host is Ubuntu 20.04.2 LTS on LAN IP 192.168.1.30
LXD v4.19 via snap
Container is on lxdbr0 IP 10.1.1.54
I have a static route on the router that reads: 10.1.1.0/24 next hop 192.168.1.30.
So from a computer @ 192.168.1.22, I can $ ping 10.1.1.54 and it will respond.
$ lxc profile show default
network: lxdbr0
$ lxc network show lxdbr0
ipv4.address: 10.1.1.1/24
ipv4.nat: "true"
ipv6.address: none
type: bridge
$ lxc config show test
user.network-config: |
version: 2
ethernets:
addresses: [10.1.1.54/24]
gateway4: 10.1.1.1
nameservers:
addresses: [10.1.1.1]
ubuntu@test:~$ ip addr
16: eth0@if17: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:02:4e:a7 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.1.1.54/24 brd 10.1.1.255 scope global eth0
inet6 fe80::216:3eff:fe02:4ea7/64 scope link
ubuntu@test:~$ resolvectl status
Global
LLMNR setting: no
MulticastDNS setting: no
DNSOverTLS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
168.192.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 16 (eth0)
Current Scopes: DNS
DefaultRoute setting: yes
LLMNR setting: yes
DNSSEC setting: no
Current DNS Server: 10.1.1.1
DNS Servers: 10.1.1.1
After openvpn client starts…
4: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 500
link/none
inet 10.10.66.67/26 brd 10.10.66.127 scope global tun0
inet 10.10.66.69/26 brd 10.10.66.127 scope global eth0
Link 2 (tun0)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 10.10.66.65
80.67.14.78
DNS Domain: ~.
